Hi
I am looking at buying a motor which has already been removed from the car but would still like a compression test carried out so I know its 100% good
Just wanting to know is there any way to compression test a motor which has been removed from the car, I have never heard of it being done but I am sure there would be some way to do it?
Its an RB25DET which has approx 80,000km on it so I would be expecting compression to be about 150 across all 6 cylinders?
Anyways any help would be appreciated
Thanks
https://www.sau.com.au/forums/topic/227594-rb25-compression-test/
Off the top of my head you could run a rubber wheel against the belts or crank pulley using a high speed drill or similar.
Removing all plugs first of course.
Or fit a pulley on the drill then run a belt to the crank pulley.
so it will be fine to crank it with the motor sitting on say an engine crane?
It won't jolt or twist when the starter kicks will it?
Thanks
yes yes it will jolt and try to twist.
removing the spark plugs will reduce this and allow the motor to spin easily, but this will affect the actual reading on the guage. you want all cylinders within an equal reading, the number it shows can be inaccurate
Alright thanks
What reading should be expected?
make sure it has oil in it
Will do
readings may not be quite as high or as even or as accurate, comp tests are supposed to be done when the motor is at normal operating temp. But should be an indicator.....I mean if the bore is shagged, it will still read low on that cylinder
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
