Has any one heard bad things about GCG turbochargers
Im bout to buy these parts for an rb25/30
exhaust manifold
intake manifold
Gt3040
bosh 044 fuel pump
tial 38mm wastegate
tial 50mm BOV
XTR fitting kit
intercooler kit
Malpassi Rising Rate Fuel pressure Reg
Turbo cover
I live in perth and if anyone knows of somewhere better to get these parts
please share. :O
https://www.sau.com.au/forums/topic/227602-gcg-turbochargers/
yeh know that but dunno if GCG have bad rep.
their prices reasonable?
delivery times ok?
have only just started with enquiries and was told bout GCG
If there is sumwhere decent in perth that anyone recomends id rather deal with them..
Well have a look, its in your own best interest to shop around mate.
You'll soon see if the price is good or not, there are heaps of turbo sellers in Aus and prices can vary month to month depending etc.
re: delivery times, ring them and ask em how long.
GCG, MTQ, ATS, ATP etc, all sell turbos, all are fine
I have no problem with GCG as they are local to me and so it's convenient.
They are a bit pricey on a few things but having local support is worthwhile so it doesn't bother me so much.
You don't want a malpassi reg. Waste of money.
My other issue is the fitting kit. It is handy as it has all the bits you need to fit up the turbo but if i were to do it again i'd look at getting the water lines in braided speedflow or earls lines rather than the heat sleeved rubber the gcg kit comes with. I have already cooked one and have since redone the water lines.
If i were you i'd find a local turbo supplier for all of the little bits and pieces like gaskets and lines, check the traders forums for good deals on the turbo and wastegate, manifold etc.
It can be hard to get to talk to Brett Lloyd of GCG but there's not alot going on in the Garrett performance turbo world he doesn't have access to .
BTW the 7 year HKS/Garrett exclusivity tie up is long over so basically if Garrett make the parts he can supply if available ex Garrett Japan .
IMO the Garrett marketed GT3040 (GT3082R) is a dog , that's not to say it won't work it's just that you can do better .
The GT3540R (GT3582R) has a larger turbine that's better suited to driving that compressor wheel .
Again IMO if you must use a GT3040/GT3082R get the HKS spec one because its compressor is an 82mm 50T rather than an 82mm 56T and more within the capabilities of the GT30 turbine .
Comp housing wise the HKS spec 50T version uses a garden variety T04S 0.70 A/R one so nothing special on the cold side .
Gotta run , cheers A .
on the topic of garret turbo's from gcg...
whats the general opinion of the gt3071r (internal wastegate) with the gcg rear housing/6bolt dump for a rb25's?
simonr32 had very good results with that turbo. He'd be the guy to comment on it. I know cubes has commented how well that turbo works with an rb25 somewhere on the forum
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
