Has any one heard bad things about GCG turbochargers
Im bout to buy these parts for an rb25/30
exhaust manifold
intake manifold
Gt3040
bosh 044 fuel pump
tial 38mm wastegate
tial 50mm BOV
XTR fitting kit
intercooler kit
Malpassi Rising Rate Fuel pressure Reg
Turbo cover
I live in perth and if anyone knows of somewhere better to get these parts
please share. :O
https://www.sau.com.au/forums/topic/227602-gcg-turbochargers/
yeh know that but dunno if GCG have bad rep.
their prices reasonable?
delivery times ok?
have only just started with enquiries and was told bout GCG
If there is sumwhere decent in perth that anyone recomends id rather deal with them..
Well have a look, its in your own best interest to shop around mate.
You'll soon see if the price is good or not, there are heaps of turbo sellers in Aus and prices can vary month to month depending etc.
re: delivery times, ring them and ask em how long.
GCG, MTQ, ATS, ATP etc, all sell turbos, all are fine
I have no problem with GCG as they are local to me and so it's convenient.
They are a bit pricey on a few things but having local support is worthwhile so it doesn't bother me so much.
You don't want a malpassi reg. Waste of money.
My other issue is the fitting kit. It is handy as it has all the bits you need to fit up the turbo but if i were to do it again i'd look at getting the water lines in braided speedflow or earls lines rather than the heat sleeved rubber the gcg kit comes with. I have already cooked one and have since redone the water lines.
If i were you i'd find a local turbo supplier for all of the little bits and pieces like gaskets and lines, check the traders forums for good deals on the turbo and wastegate, manifold etc.
It can be hard to get to talk to Brett Lloyd of GCG but there's not alot going on in the Garrett performance turbo world he doesn't have access to .
BTW the 7 year HKS/Garrett exclusivity tie up is long over so basically if Garrett make the parts he can supply if available ex Garrett Japan .
IMO the Garrett marketed GT3040 (GT3082R) is a dog , that's not to say it won't work it's just that you can do better .
The GT3540R (GT3582R) has a larger turbine that's better suited to driving that compressor wheel .
Again IMO if you must use a GT3040/GT3082R get the HKS spec one because its compressor is an 82mm 50T rather than an 82mm 56T and more within the capabilities of the GT30 turbine .
Comp housing wise the HKS spec 50T version uses a garden variety T04S 0.70 A/R one so nothing special on the cold side .
Gotta run , cheers A .
on the topic of garret turbo's from gcg...
whats the general opinion of the gt3071r (internal wastegate) with the gcg rear housing/6bolt dump for a rb25's?
simonr32 had very good results with that turbo. He'd be the guy to comment on it. I know cubes has commented how well that turbo works with an rb25 somewhere on the forum
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
