  • Replies 167
Posted Images
excels r fooly sik uleh :D
-D
It was literally sick, just had to get new CV's put on it, joy.
Oh and my car, after the third delay and being assured this morning it'd be ready today, is now delayed again coz the power steering pump is shot. Another couple of days so maybe Friday, but I might make other arrangements so I can drink. Missus hasn't finished her lessons in a manual yet. :D
hey ash what you been up to mate? haven't got the bike anymore, last time we caught up you were hobbling around schutzenfest on crutches
Still got it, but since i fell off it stone cold sober I'd rather not have a brew and ride, well since I still haven't got my lazy arse off L's I can't anyways. :wub:
hey Nick do I remember you are getting there early? I finish work at 5:30pm and can go straight there if you wanna down a few beers.
I'll definitely be going there straight from work drinks (horay for the beer fridge), which is 10 min walk away, so you'll at least have my wondrous company. :laugh:
sweet Ash, will be good to catch up!
I might have to arrange a way to get rid of my car and get the wife to come pick me up too - hang on - will Julie be coming to pick you up? I could stagger home from your place :D (or she could drop me home). Oooh this is sounding like a plan coming together :)
I might have to arrange a way to get rid of my car and get the wife to come pick me up too - hang on - will Julie be coming to pick you up? I could stagger home from your place :) (or she could drop me home). Oooh this is sounding like a plan coming together :(
I'll see what we can arrange. :(
sounds good, i'll be leaving work around 3.30, so gives me an hour or so to kill before i head down
Flick, myself, sam, adrian, scotty and dani were thinking of coming if theres room, if not, we will book a different table and we can all talk shit/drink piss together in sports bar area! let me know!
Thats fine! I booked a few extra seats anyway! But then.. think i booked too many anyway.. cos if history is to go by, ALL the people that say they will go.. dont go and we have plenty of spare seats..Happens every time.
So yeh, more than welcome! :worship:
^^ Course its not too late Guy! :domokun:
I booked 24 seats :devil: but im pretty sure we wont have that many.. if we somehow get more, sure we can squish a few extra seats.. but all good :domokun:
So whos gonna supply a dobermann or german shepherd to guard all the pimpmobiles? :domokun:
