Hi Guys,
Have a mate wanting to start of with some duttons and do targa one day, this has come up for sale and just after some help, i have read the Targa Regs on there site and i dont belive this car would be able to run as has Differant Turbo set up, Can some one please confrim this as the owner in Tassie has used the car for targa a few years back but not sure if would comply with todays rules?
Here is the add for sale:
http://www.my105.com.au/classified.asp?id=13515
oh is that right..?? Specs? and why do you want to sell it when you telling me how good they are? *upgrading to GTR*??? :P
P.s Back on topic...I might be gracing my presence at Targa this year as a Nav :) Cant get to excited cause still in discussing stages but fingers crossed and still awesome to be asked!!! :O !
WOW 6 replies in 30mins...
that car has been modified a fair bit since it's proper targa days for the local circuit series, and afaik would need to be changed to fit into the rules.
Will give it a miss as will need to much change over work, was after somting newer as well.
If any one knows of any other cars for sale let me know, Really after a RWD Nissan..
They're a great car, cheap to run, quicker than most people know, fun to drive, yeah you're right, I'll keep it ;)
And good news! Would be great to see you there, get Timmy to give you the hot tips..... I said tips, not tip. :O
Who with? Any word? About the bird? Bird bird, bird is the word.....
Edited by Marlin
YAY!! Nah not really I am still undecided myself looks the goods tho ;) I just wanted something I can race :O
They're a great car, cheap to run, quicker than most people know, fun to drive, yeah you're right, I'll keep it :P
Oh walked into that one! :)
can't we just change the title of this one... gotta sorta attached to it now!
there was a message in my last post... obviously no one checks their email!
Only person that can win it, the one with all the money!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
