I'll be watching Rookie with lots of interest!
Matt's a great steerer from what I've heard, the Evo boys can obviously punt the thing along, so it's going to be great!
I'm really looking forward to seeing Matt's blue car post transformation into a racer :ermm:
Im looking forward to seeing how these two guys go in Rookie, a couple of locals who compete in our state series. I don't know that they will be on top come thursday night, but considering their age (both only about 20) and budget, I could have only dreamed to be doing something like that at their age.
http://targa.com.au/Competitors/profile.ph...ye%20-%20Modern
So what are the tips for placings?
Tony Warren for Showroom?
Jimmy for Outright?
Peter Eames for Classic?
Yeah I know Handbags, Danny and Mario call all steer well in their selected EMO's and don't forget Andy Barlow who runs around in the Australian GT Championship in an F360 and was the 2009 Porsche Club of Vic champion who will be running around in Matt Close's old 996TT.
Fun times in Rookie indeed!
My tips...
Modern - Jones GTR
Showroom - Warren Evo
Early Moddern - Beable GTR
Classic Outright - Eames 911
Rookie - Rickards GTR
Weather forecast is still wet so there are plenty of variables that need to come into play
We're relocating the office space to Silverdome tomorrow... little bit exciting kiddies!
The excitment is killing me, but one more day of work left... Cars are starting to roll into Lonnie as are the ppl
Whos the hot tip for The Tour? Lol!
If there was a Tour comp then Slip would win it hands down! LOL
(Slips car for those that don't know it -> http://www.skylinesaustralia.com/forums/R3...ct-t283568.html )
Well better late than never!
http://targa.com.au/Competitors/profile.ph...0Early%20Modern
Oh and Snowy, I'd kinda feel robbed doing the Tour in something like that. but atleast your guranteed a trophy at the end... if you finish!
Haha - yeah but I think Slip is building another one to run the full event in next year (I think Targa High Country will be his first event) so is using the Tour this year to test out the feel of some parts and set-up. It's not the most silly thing in the world to do consequently!
I'm looking forwards to checking it out - it's probably the most developed 35 in Oz I'd say.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
