Caught up with YT this morning to pick up some old bits he had left over from the R34 days and he says the Super Alphabet is going to be ok abeit with a weight penalty which I thought was interesting.
Also seems the Skelta's will get a weight penalty too and have to lose the S/C.
Stuart, thanks for clarifying.
Could you also please clarify the rules on gearboxes. Specifically, I'd like to know what you a free to change and what is not. Can we change gear sets provided the same casing, shifting pattern, and number of gears is maintained? Can helical gears be swapped to straight cut, and do the ratios have to remain the same? Failing that, can the lower gear ratios be changed if the the final drive (ie toptop gear) remains the same.
Specifically, I am interested in early modern skyline (LMS I think), and there is no mention of gearboxes until MS. My understanding from previous years was that there was some limited freedoms with respect to gear sets.
As far as I can read Mark the following ONLY apply to MS cars
M19. Gearbox / Transmission / Final Drive
a) The clutch is free.
b) Flywheel is free.
c) The casings and housings must be the same as originally fitted to the vehicle.
d) The number of forward gears must be standard; otherwise the internal components are free.
e) The gear change mechanisms must be as originally specified for the vehicle, other than that shortened or ‘quick’ shifters which do not result in
modification to the casings or housings are permitted. Sequential shift mechanisms are not permitted.
f) The internal components of the differential, axles and drive shafts, are free.
g) Live rear axle equipped vehicles may be modified to incorporate floating rear hubs.
So for LMS the above must remain as per factory specification
That's how I read it too, but from how I read the rules, Z tune and ATTKD and possible 400R are out, but according to Stuart are not, so I just don't know what to go by. I'm not arguing the rules, it's just better to get official clarification from Stuart.
Even if gearboxes are factory, what is the ruling on OEM parts? Can I put a gear set with exactly the same ratios and format (keep them helical not straight), ie only cheaper and/or stronger, or do I have to use genuine Nissan parts?
I think the new rules are great, but I'm not sure I understand the exclusions.
If you read it to the letter, then this also applies to the clutch, which means the skylines would be back to the factory clutch plates which are organic and wear very quickly. Doubt they would even last the whole event.
Under the old rules, as long as it was the same function, ie single plate, you could change for an aftermarket clutch plate, so at least something that would last. Gives no advantage in performance, but at least would last.
Again, I think we need some confirmation here before I start ripping the car apart.
If it is a case of having to be all factory original parts, then we are worse off than before, with the 400R having all sorts of parts advantages, and we go backwards on basic durability parts.
Yes, Steve Glenney is one of the instructors, spoke to Mick who is running the show and it sounds good. I think I'll be doing it. Here is link for outline of the day
http://www.rexnet.com.au/forum/index.php?/...a-training-day/
Brendan Reeves is also involved... One thing from these tutorials is the nav stuff. Having a calm nav because they understand what is required can be worth about 1/2sec/km I reckon
Just doing a wooster and dropping in to the other side for a quick peek. Seems the fallout from the showroom change is more a 4wd thing. Guess the no cat rule last year wasnt quite enough to get the 2wd's to the front. I am glad we had a run in the good old days.
TT
Haha will the fence jokes ever stop!?!?!? :D haha
No chance Ben- it's way too much fun ;)
Speaking of fun- I won't be having any unless I can sort out a new seat.
Yep Handley & Handley looks to be no go for THC.
Anyone know of anyone looking for a nav?
Can't remember who was up on the embankment on the Silverdome this year furiously applying rain-x or trying anything and everything to prevent the screen fogging on day one. Del over on the ip forum tells me he might possibly be able to assist if you want to outlay a few sheckels and avoid the 12v dryers and not so magic potions, never know, might even get snow in November too!
Guilty as charged, and for the first time, rain-x didn't work well enough.
Talk about wet, day 5 on Aerosmith was the worst.
Ah, was thinking about a dark coloured car up the very top of the rise, asked us what we were doing, other than running around like headless chooks. Now I think of it, more than a couple of cars up there.
Aerosmith is pretty bad, although that Tyler bloke with a face like a smashed crab can pull some women! That longish stage on day 5 was almost as revolting, conga lines of cars overtaking then finding no taillights to follow, hard on the picks, repeat to end of stage. :)
Not sure there is skyline data there, suppose the first prerequisite of going at any pace is seeing the road though, screens are supposed to be around $500.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
