I think what he is referring to is his Porsche only receives basic mods like spring/shock change, pads, muffler deletion and tune... Where as the Super alphabet gets a $100k upgrade between rounds...
At least there's no more super-fancy sequential gearboxes for the Lambo allowed any more.
Jim needs to swap out the circuit springs for something more suitable.... have you watched his cars lately?!?!
Edited by Marlin
Yeah but I remember Captain Close telling me Jim loves his Tarmac Cars to be rock hard in set-up for some reason.
PS - what gearbox is YT / KW running now? Still seemed pretty fancy from the TWP footage (sure ain't a 6M thats for sure).
Hmmmm, I think his cars used to be more supple. Or maybe, his gear was just so much better than everyone elses that he could win in them? I dunno, but the way his cars bounce around these days, po-go-ing in the front, I'm suprised they don't see the scenery more often.
The lambos will be reterning to the conventional gearboxes either before targa, or post targa, I'm not sure. And yes, they were running the fancy S6 at Wrest Point.
yeah I have seen jim bouncing his porsches around for years. he seems to like them pretty stiff with lots of spring. it doesn't seem to slow him down too much, he seems to run quite short travel shocks too, I mean the things are pretty low but don't have uber rebound either as it picks wheels up pretty easily from pics and footage i've seen. maybe it helps save tyres if you can get the wheels off the deck now and then? lol.
and yeah maybe jim was referring to white but jim is not exactly doing it tough for budget either... the lambo may be a weapon but i'm not sure the GT2 would be far behind on outright pace. would be interesting to see white in the GT2. don't get me wrong I love jim and think he' a fantastic steerer, I just can't stand when people try to always cry the underdog story when he's clearly not.
I don't want anyone getting the wrong idea either, I'm not under-selling what Jim has done, the man is a legend in my book!
I still can't believe I've been as lucky to be in the same event as him :)
I think YT could drive anything quick, witness his resuly in a HQ Monaro at Rally Tas a couple of weeks ago...... to jump in that at very short notice, and do that, with a nav he didn't know, well, begs belief.
Captain was telling me once that his 996TT was originally set to JR spec and then Rex got hold of it and turned it to butter spec. (which Matt decided was 11ty x's better)
But yeah - it was him who told me Jim LOVES rock hard set-ups for his Targa cars.
"Beer Baron"
will be cool to see walter rohrl there but not sure how he goes these days at 65.
If he's even half as quick as he was at 55 in that breadvan 356 last time, Rex B and co will be minutes behind is my prediction. Was braining them in late classic even in that 50s scheissen boxen after a couple of days, his back and seeming lack of mechanical sympathy, the jokers in the pack.
Jum is always good for a quote!
I laughed a little bit when I read about his "pretty much standard road car" to paraphrase.
Not forgetting that he was the worlds gun touring car driver for pretty much his whole career !
yep, but I'm on the hunt for somethin else..... GTR rear end going in it now.
You just opting for the lighter hub assembly ben?
See that MCA offer a Sliver Series (mass produced product) for a selected range of vehicles now?
Nah, just figured while it's completly apart I might as well. Will make it easier to add ABS later and gives stronger shafts too (not that I had or would expect to ever break one).
Gonna miss my diff though! The one I've bought has a Nismo centre, but..... whatever is in mine now is the shizzle :)
this is way off toppic but i would opt not to got for gtr rear end. why to heavy everywhere. if your running a 20 stick with it. unless its a drifter making 300kw you wont brake shafts often enough to matter.
Benson's ignoring my calls and emails..... so i think it will likely be my first targa no-show in seven years.
Thats not like Stuart :P what have you done to offend him???
If he's not answering your calls im sure i'm even further down his ignore list! I'll have no hope of borrowing a Pov camera off him now for next weekends rally :(
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
