Recently copped an epa violation, just got tested, im 10dB over :)
Exhaust dude said if i can find the flange for my exhaust (3in 4-hole, cant seem to find anyone who can tell me where i can find one), he'll weld the new muffler onto it, and i can just bolt it off and put the old one back on after its tested.
So therein be my problem, locating this flange. Ive had a suggestion that i cut all the flanges off and put standard 2-hole flanges in. Is this advisable?
Thanks in advance for any advice or suggestions,
Nasha
https://www.sau.com.au/forums/topic/228125-epa-violation-what-to-do/
Can you get something put in it to muffle (quieten) the sound a bit?
Well in theory yeah, and i've heard of people doing this, but not exactly sure how its done. And i imagine if not done correctly its just gonna spit out whatever i stuffed in there lol. And it also means i need to goto another tester :)
Anyone have any input towards this idea also??
why dont u just locate a factory cat back? or something quiet enough. bolt it on. get it tested, pass it and then put ur old one back on.
dont go welding crap.
Thats an option i hadn't thought of funnily enough... But sadly, i dont know if my exhaust mod is cat back or turbo back (performed prior to recently purchasing). I'll take a look tomorrow and see if its a viable option
yeh do that.
regardless of if its a turbo or cat back, just replace the catback with something quiet. that way its a easy bolt on and off when u pass the test.
and if u ever run into this trouble again you can just do it again. all you need are jacks or a hoist.
yeh do that.
Im just a bit worried about this strange flange. Maybe the entire exhaust setup has these strange flanges, and i wont find anything to get onto it
the flange only applies to the muffler i believe.
catbacks all have a standardized connection these days. just take it to a local exhaust shop theyll be able to tell u wat it is.
Well thats a good start, but whats the chances of finding a catback exhaust thats cheaper than a muffler itself?
yeh do that.
Except next time you get caught for the same EPA violation its $1000's in fines.
Just replace the cat with a stock one, surly your running a 3" or bigger and its more flow the stocky doesnt flow well at all.
You may wish to look at a EPA tune too (tuned to meet epa standards)
Edited by DECIM8
Any welding shop can plasma cut a flange, all you'd need is a gasket for a template. Buy a peice of 3/8" x 5" square plate and cut it out yourself, cost $2.00 and couple of hours.
All you'd need is a pencil, center punch scribe, hammer, half round file, and a drill with a small bit.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
