Okay, so unless I am doing something completely wrong my car just doesn't exist. It has never been made.
I put in my vin. (ECR33-056052), I put in my model number (GGKBRTFR33VDA-U---), I put in my model series number (ECR33), and yet nothing is happening. Just says that my model series and model can't be found for my VIN and that my model and everything else I type in are wrong. Do I need to know something about enterenting this shit?
I have tried putting ECR33 in the first box and then 056052 in the second box. That didn't work so I tried to put it in as ECR33-056052 but it extended it with all 00000's. Maybe I need to add 0's to mine? What on Earth is going on?
https://www.sau.com.au/forums/topic/228338-nissan-fast-my-car-doesnt-exist/
Hey, not sure, but it's not coming up in our system, either. Might need some more information about the car to see what's going on here.
LOLOL WOW!!! The chassis number AND the VIN number are on OEM Nissan plates UNCHANGED. I can take a damn picture....
Maybe my car is so rare Nissan themselves don't even know about the damn thing...
What information would you need mate?
Edited by AKW
Actually, it isn't R34kid. That is your Chassis Number, AKA your VIN. I asked for the Model Number AKA your Model Number. Look again.
I GOT MY PROGRAM WORKING... okay, I will be running your now R34kid.
Edited by AKW
Ive got a 2001, 2007 and 2008 version of FAST, ill check the VIN when i get home.
One thing I have noticed on the 2008 version is that most, if not all, VINS exported from Japan, aka 'ours', have been removed/deleted. (prob not relevant in this case as most people are using '01 version).
VIN - BCNR33-041211
Model - GGJPRQFR33ZDA-AP-C
Series - R33
Production M/Y - 97/03
Color - KR4
Int Color - K
2k
RB26DETT
HICAS
4WD
MT.F5
thanks mate, what does the 2k stand for? anyone know what the zda - AP and C stand for?
Edited by R34kid
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
