Hi guys,
I'm adding a 4 gauge power wire for my sub, and I've searched everywhere but I can't find a hole big enough to fit it through.
I've already got a 8 gauge going through the same hole as the boost gauge wire but the 8 gauge bearly fitted and the 4 is way thicker.
Has anyone done it before? And how did you do it??
Pic's:
Jack the car up turn or remove the right wheel, remove or loosen the plastic inner guard and route the cable from the engine bay into the rear of the guard and then into the cabin through the large grommet that the main wiring harness runs through.
Do it!
hahaha i was thinking that too, but the drill wouldn't reach.
I opened the guard and I know what to do now, but there is this tight rubber surround thing that I can't get the 4 gauge wire through, should I just cut a hole through it ???
Hey guys I did this today and it was much easier then I thought.
I didn't even jack the car up, just turn the wheel.
Again thanks for all your help, really appreciated and without it I would have had no idea what to do :(
Thanks everyone :thumbsup:
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
