GOR Casualties...Late but here..
Guest RedLineGTR
Well after a nice monday, i come home to see a letter on my table...i wonder to myself what it is and i open it and i find a nice blue letter. OH great thats all i need to start the week...it was from the GOR cruise and thank god it's only that much, they must of caught me in one of the towns or something. No idea where it was. Good we wernt speeding on the road i was unlucky. All the high speed runs we done on a old airfield it was nice, so we kept to the limit on the roads, oh well shit happens more money to waste.
My Nice peice of paper
:D;):D :D
https://www.sau.com.au/forums/topic/22852-gor-casualtieslate-but-here/
64km/hr hey.. you're a danger to all sane people and are going to kill somebody anybody any second with those 4km/hr over the limit... Thats pretty rough though :D Although those zones will soon be 50km/hr give it a few months.
I'm glad I wasn't driving now. Wonder how many others are going to recieve a similar notice?
Guest RedLineGTR
omg i'm going to loose it going over 4km/h...quick i'm a menace to society...Yep Victoria...Steve Bracks you Poof...
Oh well i assume if anyone else got one they will get it within this week. Oh well only abit over didnt go much over that speed while on the cruise, i guess just bad luck. Eh :D
3km/h over and you're booked!
I SAW THAT CAR!!! It was a Magna I think, with a camera box in front of the bumper, people from other direction been flashing on us, and I stomp on the brake, hopefully when I pass that car my speed didn't creep over 63km/h... very tricky.... finger cross...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
