i might be trippin.
but i own an r32 gts-t i havent really driven any other manual r32's so its hard for me to really comment but
basically ever since ive owned the car i find it hard to gear change quickly? for example i need to give it a few split seconds
before getting it in the next gear its not that bad but makes it hard to snap gear's niclely on a track if you know what i mean.
other manuals ive driven are easy as so its not me but i think maybe there could be a problem with my trany?
just wanna hear other guys views. are they all like this?
also been told to shorten the shifter with one of those ebay kits you can get? might help?
not sure mechanic says it is a bit hard to gear change in my car so he's changing oil but i think it was changed recently
does any one know much about it? sorry for the long post. cheers
https://www.sau.com.au/forums/topic/228858-cant-get-a-smooth-gear-change/
one other thing i forgot to mention is that it has always been really hard to find reverse in the car you need to pull it right to the side before pulling it back into reverse other wise it wont slot in not sur if that means anything?
Using a short shifter will make it harder as you are loosing mechanical advantage on the lever. It will also wear out your synchros faster. I'd recommend doing the oil change in the gearbox, maybe use something like that redline shockproof?
Just read your signature, if you have that much power and your '20 gearbox is on it's way out, might be time to look into an RB25 box, especially if you intend to be snapping gear changes on track.
Edited by daisu
yeah thats what i thought. i know that the box will go next but you can always hope i suppose.
just still wanna know if it is normal to find it a little hard to find gears or are most 32's with a good box smooth not sure cause i dont have many mate's with 32's?
its yeah id say all of them obviously alot easier going from 3rd to 4th but 1st to second is kinda stubbourn its really not that bad but its not as good as other manuals ive driven
it almost feels the way a van or a 1 tonne ute is
can you get syncros fixed or replaced or is that part of the box? dont know much about transmissions.
reverse is the very hard to engage.
All my gears in my rb20 box are notchy when shifting in. I try to rev-match so its a smoother change :D
Reverse gear sometimes locks me out and have to depress clutch and try again.
If you want to rebuild your rb20 gearbox, it will be around $900 trade-in.
http://www.japanesegearbox.com.au/intro.html Located in Rowville. Last time i was there they had about 10 fully rebuild rb20 boxes on display.
I think they also said an extra $150 for gearbox swap
Give them a shot if you decide on swapping.
Although with 260kw~ might be better to get a 2nd hand rb25 gearbox as they are much stronger.
Although im in the same position and cant decide wether a 2nd hand rb25 gearbox is better than a brand new rb20 box ;)
Hope that helps
Cheers
Patrick
definately not the clutch just changed it and it was the same before..
any more views?
Did you adjust it at all or just threw a new clutch in?
Reverse doesn't have synchros so I can't see how a worn gearbox can result in you not being able to select reverse..
Although im in the same position and cant decide wether a 2nd hand rb25 gearbox is better than a brand new rb20 box :D
Definately worth it. I was sceptical when I first put mine in.. $1500 is a lot to spend for something you aren't sure is going to work but since putting the 25box in, I don't regret it and think it was a much smarter thing to do than put ANOTHER 20 box in again.
my mechanic replaced my clutch and transmission oil. so im guessing he did all the adjustments to it...
considering there was no engine in the car when he replaced it im sure he had a resonable look inside.
any way yeah i think ima start lookin at a 25 box for the power i have my box wont last long...
how much do you think a 25 box is $1500?
for a second hand one? is that not including labour to put it in?
rb25 box sells around $1200-$1800 for a second hand one.
You'll also need some slight customizations to make it work in a r32 too, but i think there are several threads discussing this already :(
I just got myself a 1 tonne clutch put into my 32t and i have the same problems .. usually hard to get into 1st and reverse...but the other gears feel really notchie
mechanic took it back adjusted the clutch and it was fine after that ... you might wanna check your clutch
New clutch, needs adjusting.
Also, my 25box upgrade was about a $2.5k excercise with the full custom tailshaft I had made and purchase of senders, oil, etc. (paid $1500 for a secondhand 25box)
Edited by bubba
  • 7 months later...
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
