Ok. The question is i own a 96 S2 GTS-T and i am having a hard time finding a Wind deflector plate for my model as most major manufacturer only made it for the S1 GTS-T and GT-R.
Example;
BNCR33 TFPBCNR3303 For earlier model 1/95-12/98
BNCR33 TFPBCNR33M03 For later model 1/95-12/98
Now I own a S2 GTS-T, if i buy the BNCR33 Later model version TFPBCNR33M03, can i fit it on my R33 with slight modification as the only main difference between the GTS and GT-R is the grill. In other words, i may need to cut a bit from the grill art to make it fit, can i get a confirmation on this.
https://www.sau.com.au/forums/topic/228915-arc-titanium-hood-panel/
mate your asking a lot of questions lately which is good, but rather than product numbers from nengun or whatever you have given us, you would get a lot more responses if you actually showed a pic or explained what you were talking about.
I for one am happy to help, but cbf looking up something for you.
This is what i am talking about, it has many names like wind diversion plate, wind deflection plate or whatever it is called. lol. Reason i asked here is that i got the answer from the supplier that it WILL NOT fit a GTS-T S2. I am thinking, why won't it as BNCR33 and ECR33 share the same chasis except for the grill, the front area should be identical. So the final question is, can this be modded a bit to fit ECR33 S2.
Btw i won't ask questions if it's a direct fit part. lol but i do take chances as well like the M35 Nismo muffler on my R33. I bought it without knowing will it fit my car or not so i do gamble on parts if i can't get a definate answer here.
I maybe asking alot of questions but i am solving some as well :/
Edited by teng
from my knowledge it wont fit hence why theres a model for the gtst and gtr. different placement of bonet latch maybe or even adaptation to fit snug with gtr grill and lights.
so you've bought it already. why dont you just test fit and see where it doesnt match. anything can be modified to fit. you will get less for it when selling it off cause its been choped.
Nope, i haven't bought it yet, hence i'm asking around here for some advise first :/
From what i searched, ARC doesn't make one for any R33 GTS-T, Garage Defend only makes it for the R33 GTS-T S1. Greddy doesn't have it for the R33 S2 as well.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
