  • Replies 665
Posted Images
Uhh Adrien I used Netbank to transfer the $50 immediately after I posted. I took a screen shot of the receipt page just in case, do you need me to send it to you? It may not go through immediately though, but I definitely paid.
If there's any issues please let me know, Tom.
Net bank is pritty much an instant tranfer i beleve so it should have gone in just after you completed the online form...atleast mine did any way and has every other time when using it.
yaaayy for hoodies haha cant wait :cool:
It is instant transfer from commonwealth bank to other commonwealth bank account... commonwealth bank to non-commonwealth bank takes 1-3 days to show up on the other account depending on the other bank.
wait till the whole transaction is over with then do ratings :cool: yours will sky rocket GB ftw on trade rating
ps... im not gonna go chasing up who havent paid!!
if i dont have cash u miss out! bad luck! u have had 2 weeks!
any problems let me know!
thanks!
now to trader rate everyone hahahahah
well there ya go ya learn something new every day :cool:
hmm im wondering if i should have botherd with postage now lol,it would prob be better if i picked it up so i could meet everyone one who i havnt already met.
Sorry dude, just got back from 3 months in the middle east and only saw the post yesterday. Just return the money then if that's ok.
thanks!
mm didnt get on in this one, might try for the next one. was thinking i might just be able to go to t-shirt city and get the design done myself, was thinking id just reduce the size of the SAU on the front, instead of the S on top and the AU on the bottom, just a smaller SAU in line, roughly the same size as the name next to it.
Will probably be stupidly expensive for the shop to set it all up for one shirt nisskid, but if you do, let us know what the price was.
Guys, don't forget to trader rate me to :cool:
Thanks alot to everyone who paid cash last night with their exact (or very close to) change, makes it 100x easier to manage.
you want a top looking T-shirt you will have to ask Jess aka >>Sinful<< about this
Bring on the friday when we pick them up :D
+1 :banana::banana::banana:
Thats a real nice looking t-shirt design. :( But im keen for my hoodie :D
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
