  • Replies 665
Posted Images
The order has been placed. Just waiting for a member to re-select a colour (which I guess was available at the time of ordering, but not now). These things happen. Delays are a part of life. Suck it up princess. :D
On another note, I WANT HOODIE! :)
Can you calm the f**k down? Hoodies are coming, like its been said a million times, waiting on ONE PERSONS colour choice. That user has now been given black as default, and i have sent off the final changes today.
After the quality of feedback i recieved from my updates, i think im going to keep you guys out of the loop until we get them. They are going to be here soon, and thats all you really need to know. Ill get back to you with a pick-up date.
"dont be racist" dont read on if u are easily offended
what do u call an aboriginal in a ferarri? a theif
why is it always sung to the left to the left. cause black ppl dont have rights.
an aboriginal traded his gf in for a toilet seat. he said the hole was smaller and it didnt smell as bad :sick:
soo soo harsh. but u guys needed a pick me up. laterz :O
Edited by johnzey
Damo can always not send them to you, how about that? You get them when you get them. Next time i say people in other states are excluded from the group buy :thumbsup: ... I kid, i kid.
Cant wait to get ma hoodie :) i dont care when we get them, so long as we get them!
    • My car is also flex tuned. It's worth mentioning it (the LS1 ECU) has a 1D table for E85 addition and just uses the ethanol stoich part as the second point of reference. It also as a 3D timing map for Ethanol adjustment. You would think this isn't enough but it works pretty damn well. That said, I wouldn't want it in turbo application. It's like lifting non-natty, or taking meth. It gets you unrealistic results that break down more things going forward. If people used it to make the same amount of power they do on 98 then it'd be one thing. But people use it, crank it up to eleventy million PSI, it doesn't knock - but it pushes the point of failure to another, more expensive thing to break. Every time I see someone make 280kw on 98 and 350kw on E85 on the same equipment I just cry a bit and really wish they would just stay on 98 in that exact scenario. It's bad for you.
    • This is kind of what I was thinking but the temp sender wire and the two pressure switch wires run through the starter subharnes and I eliminated the two pressure switch wires completely.  @GTSBoy I have a can gauge with unusually bright warnings should the oil pressure fall so the factory light isn't needed. I need to dig out my wiring diagram and see if I can sort this out.
    • It's a valid point. And it is doable with the Nistune. But I'm not inclined to flex it the way Nistune does - certainly not on a Neo ECU. They're already pernickety enough to tune just one one fuel. And of course, I'm not that interested in putting in a Link or similar, on a daily. With the stock ECU, stock looking turbo, etc etc, I still stand a chance of surviving a run-in with the plod. Last time it went over the pits (which was for the transplant, for because of a run-in with the plod), the Nistuned ECU did not even raise an eyebrow. They want to see a stock ECU running the engine, and they are happy to see it do so without the check engine light** on. Never mind that the Nistune is necessary to make the stock ECU work in a different chassis without ABS, TCS, etc. **And they actually provoke the CEL to come on by disconnecting the AFM, to prove that the globe hasn't been pulled!
    • This is why you flex fuel it...
    • That is what I took from it too. Needed to go AWD S14 imo.
