I followed the house from the boost soloinoid and find that it has 1 restrictor then if another house after the restrictor which continues on also has a restrictor. do i need to remove both?
i have attached a pic thanks
Edited by skline01999
https://www.sau.com.au/forums/topic/229273-boost-restrictor-r33-gtst/
i don't think there should be restrictors in there as they would lower the fuel pressure.
there shouldn't be a boost solenoid in that line. if it is an EBC the map sensor can go on that hose, but not the solenoid. that should be on the line to the wastegate.
yep, that one is the factory boost restrictor. why do you want to remove it?
it wont get you higher boost. its there to regulate the pressure, so you dont get spikes. if you were to replace that restrictor with a more restrictive one, that would get you higher boost. ppl call them boost jets.
if you're running a boost controller, then you should remove it, otherwise leave it.
Edited by Munkyb0y
Interesting Munkyb0y...
I would have thought you'd get an extra 0.1 - 0.2 Bar or so...
I was thinking about doing this on my GTR but I questioned it to my mechanic and he said don't do it either. "No such thing as cheap Horse Power" as he believes.
When you say "to regulate the pressure, so you dont get spikes", is that also to stop the car from 'over boosting' itself? And save your turbo(s) from blowing up?
Thats just what i read on antoher topic on the forum that it will increase boost, so I wanted to try.
no it wont overboost, the solenoid controls that
it just makes the boost more linear, rather than surging.
if you think about it, a boost jet, which is a restrictor, placed in that line will hide some of the pressure from the wastegate, and allow the wastegate to stay closed longer, therefore reaching higher boost.
so removing this restrictor wont increase your boost.
edit: this is all useless with the stock boost solenoid, because that controls the boost in the end.
Edited by Munkyb0y
I too have heard about that and my have posted in that thread, cuz I read there is Boost restricter in the hoses. Its like a small cylinder that you can squeeze out then plug the hose back in.
I read that the hose has a small yellow marking, indicating that there is the restrictor and when removed, you can have a Safe Factory Boost increase. But I have not found any solid evidance of this and Iam not willing to try it.
try it. just replace that restricted hose with a regular silicone hose. see what happens. who knows, i might be wrong. but i'm fairly sure max boost wont change while youre using the stock solenoid. btw this is for R33. i'm not familiar with the r32 and gtr setup.
Edited by Munkyb0y
I see, that makes sense.
Best leave then. Thanks.
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
