  • Replies 239
Posted Images
lol drdoof now you tell me lol
cars washed.......... need help putting long sau sticker on my back window,,,,,, when in carpark can someone give me a hand.... cheers
2nd post yeah was an excellent run.
woo first after post! :D
twas sick, I have a few pics, I'll chuck em up in a bit...
best car there was mine for sure :)
Thanks for the free fuel Pezhead :rolleyes:
Hey Doof, maybe we can just run a line from my exhaust into your petrol tank - like a mid-air refueling rig. Hehe lol!
Great cruise, was really good to get out and meet some of the Sau'ers, and to put a face to the names :)
Didn't use much fuel up either ;):D :D
Lol @ lancer being left behind at the ferry :D
and wtf @ Albert, showed up then left........ :rolleyes:
Got a few pics, will put up laterz
Oh yeah, almost forgot to upload that picture.
I call it "Lonely Lancer"
Wahahaha!!!! OMG! thats awesome!
Yeh lil Albert deff missed out, so did Ryan aka "huh"
Love the looks a whole line of skylines get and we cruise past :rolleyes:
And how nice were those 2 34 Gtr's *drools*
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
