hey guys im looking for R32 shell??? can pick up as long it isn't to far away. umm... basically doesn't need anything in it have all my running gear/motor/gearbox/interior etc but willing to buy one that is only missing motor and gear box etc. let me know if anyone has anything :D cheers.
https://www.sau.com.au/forums/topic/229351-looking-for-a-r32-shell/
Where are you from so we know how far to far is??? GTR or GTST????
i live in northern nsw, um... haha the closer the better as long as it's no further then i dunno 10hrs away??? so say eg: sydney to gladstone. but if i found a good one further away i woud look into getting it here. a GTST or a GTR either way just need a bare shell or even a GTS shell would do, but a GTST would be best. putting a rb25det in it.
yeh going to be a track car so it doesn't need compliance, where is nisswreck located though arn't you guys in melb??? getting abit far a way i think freight would cost me a arm and a leg to get it here???? what price range are the shells you hav???
cheers
I have a white gtr shell missing radiator support. They are the same as gtst. The guy I bought it off said he used it to repair another car. Dead straight and no previous accident history as it has original paint. Has almost all interior and rear diff etc. Has 17inch lmgt2 rims and adjustable height and damper apexi shocks. Would be perfect to run rwd. Looking for 4k and it has import approval under the old scheme. 93 model. A rwd 25 will bolt straight in. In melb though.
Was going to build it myself into a track car but I've lost interest atm. It comes with stronger lsd diff and drive shafts on a better chassis. You can't go wrong.
I have a rolling R32 GTR shell in Melbourne for 2k but it had some rust (nothing major, but none the less, it is rust)
Maybe this could work well for you, weight reduction??
PM me if interested as I probably won't see this thread again.
Greg
  • 1 year later...
hey guys im looking for R32 shell??? can pick up as long it isn't to far away. umm... basically doesn't need anything in it have all my running gear/motor/gearbox/interior etc but willing to buy one that is only missing motor and gear box etc. let me know if anyone has anything :ermm: cheers.
hey mate, i have a black R32 gtst...COMPLETE car minus engine and box...gtr front seats, momo steering wheel, 3 inch cat back exhaust, king springs..only thing missing is the left head light...$4000
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
