hey im buying springs and was wondering if i should do the job with friends or go to a suspension place and do it. my friends done this kinda thing before but my other friends are saying its too dangerous
Personally I am one for doing as much as i can myself as i hate paying huge hourly rates and im all about learning. Changing springs really isnt a massive job and as long as you have a spring compressor (or 2) the job is really quite easy.
Cheers
Cam
yeah do it yourself, just be sure to seat them properly in the rubbers... you need spring compressors ($30)...
If your lowering your car remember that you will probably need an alignment so if your unsure about your install get them to have a look while their at it... but its a pretty straight forward hardware change. just annoying to do especially by yourself, two people would make it quicker.
ok thanks. so its just a straight swap?? swap the stock with aftermarket?? a few of my friends have told me there are things i have to ajust and if i dont do it properly then the cars height will be uneven and the car might lose control.. i have a friend who did his holden himself and is willing to help but he is unsure about my 34
btw i know little about cars :down: hoping to learn more everyday
Edited by blazindragon
well assuming they are the right size springs, and you are retaining the same shocks, you can't go wrong.
If you are fitting shocks with adjustable heights (either threaded body or circlips) you need to set them to the same height to start with (just measure the height on the shock body). Once you have done say 1000klm you should measure and re-set adjustable height shocks anyway.
but this doesn't apply to springs only....go for it...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
