  • Replies 50
^^^ lol
both cars suck to drive, tha vagina pink sil sucks cuz its vagina pink hahah and the 32 sucks cuz its annoyin to drive as a daily (button clutch, coilovers, cage etc.)
kwik fix is automotive mobile paint repairs too fixes scratches, wheels etc.
Hey guys, im back on the westside (sort of), my misses and i bought a house at springfield, after growing up in centenary and then moving to toowoomba for a year and then living at kangaroo point for a while. Keen to meet a few of you, should organise a westside cruise/meetup/bbq, ill offer my place up if ur all keen, im heading to perth for a while next week, but ill be back till the 20th november and then ill be back on the 6th december, and then cause im now broke with a morgage ill be home pretty much for the rest of my life other than those dates.
^^^ lol
You guys dont live near the roundabout at caltex in sumner park by anychance, always see a vagina pink silvia there?? I work in sumner park...
Thats them John. Im still in the area. Going to that BGS 5year reunion thing? Not long enough for some fags I think :rofl:
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
