Hey guys,
like it says, I've got some noisy noisy creaking coming from the front end of my car. I guess the whole suspension n axle is acting up. Just wanted to know what could be done about it...like fluid, lubricating or having some suspension guy look at it. It's just noisy when the car isn't moving...creaks when i turn the wheel, creaks when i'm going slow, creaks when I slow down to a stop.
Any ideas or ppl i can see?
thanks,
Zak
https://www.sau.com.au/forums/topic/22958-creaking-suspension-etc/
can u pinpoint if its from the front left, right, both. with a mates help u should be able to tell if its from the top of the strut or not. mine is creaking from the top on the left only. from what my mechanic says its a case of either genuine nissan or him manufacturing his own. which he has already done but its really co$tly. mine has been creaking on and off for a month. sometimes i can go all the way to brizzy and back to the sunny coast without it making a noise and other times it will creak the whole damn time. i recommend getting it checked out by atleast 3 or 4 mechanics. get one of the $14 pedders suspension safety checks. they might pick it up. in my case they didnt but they picked up a few other problems and for $14 its worth it. good luck
I would have to recommend Simon @ Street Performance Exhaust on the sunshine coast. Unit 1/40 Production Avenue Warana, Sunshine Coast. Phone: 5493 5311. He seems to know a lot about skylines. he used to own one and they are doing up a GTR at the moment. He is a little pricey though.
  • 10 months later...
i get same on the left hand side at front... try to WB40 the entire strut and spirngs... I sprayed WD40 all over the strut/springs and then sprayed all over the top strut where the brace bolts onto. I think it fixed the problem for few months. Its back now, I mite do the same and report here if i remmember.
will check the guards as well... thanks for tip mate
  • 2 years later...
Time to dig up an old thread, Zak, did you end up finding the problem?
I'm having similar issues with mine, especially when I slow down to a stop.
I only hear it from the front left hand corner.
I'd upgraded my sway bar to a whiteline adjustable a few weeks before the noise started, and it was about the time I changed my wheels from stock to 18".
The wheels clear the calipers by more than what the standard wheels did, so I know it's not that...
Z
I have similar problems,
Particulary in the cold I used to have creaking coming from my all over the joint. I got under the car and sprayed all the joints and bushes and everything with lube, and tightened all the things that can loosen up with the impact gun, it seemed to work for a couple of months. Now I have only 1 creak, and that comes from the front right of the car. I'll try lubing up again, but I think the proper soloution would be to get new bushes (in my case) can anyone confirm this?
On another note I have another creak. It happens when I turn right around roundabouts, or 90degree corners in suburbia (with a little speed). The cars weight shifts to the passenger side, and the drivers side rises. When the drivers side comes back down as the car straightens up thats when I hear the creak. It seems to be coming from the where the door connects to the guard (rear gaurd - door handle end)... I have absoloutly NO idea what it is. Does anyone else have this problem, or does anyone know how to rectify it?
Had same problem months ago. All is good now. At first I thought it was the control arm bushes. Turns out it was the swaybar ones. Hope that helps somebody :P
Hmmm,
I've replaved my swaybar, and the D bushes front and back...
Perhaps I didn't grease them up properly.
At the time though, I thought i put too much grease (the white stuff that came with the swaybars).
lucky this thread came up again, i was about to post a new one.
last night on the way to work, no dramas at all. On the way back home, came up the drive way and i heard a similar creaking noise. It was coming from the RHS of the rear. I sort of had a feeling it is the suspension datz shit it self. after i parked inside the garage i pushed the car up and down, and it was making the creakin noise.
what do you usually have to change in regards to this? Could it possibly be the rear guard as stated above with the front guard?
any help appreciated
cheers
Edited by SLYLNE
  • 3 years later...
Did we get any resolution? i might just try lubricating everything as i have the same problem. It doesn't do it around corners or when stopping, it does it over bumps in the road and speed humps...
WD40??? or something else...
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
