87 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Clarkson loves the car, but he'll still say its uncool. It has the "wrong" badge for the price, and its too technical and anemic at around-town speeds, and not about "soul" or some other crap.
There's plenty of cars he likes and respects and wants, but aren't cool.
https://www.sau.com.au/forums/topic/229601-the-wall/page/2/#findComment-4037433
I reckon it'll end up un-cool.
Mainly because unlike Jeremy's beloved Fezzas it lacks a certain presence and theatre. And as others have said previously, you'd be constantly explaining why it looks like it does, why it is still so quick despite being so heavy, how fast it is in launch control mode, how fast the 'box shifts, and probably most importantly why it's reported to lap the Nurburgring in 7:29 yet you just got blown off by a well driven something something Gti through the twisties. :wave:
https://www.sau.com.au/forums/topic/229601-the-wall/page/2/#findComment-4040921
On the R35 at Fuji, it was great to hear Jeremy C saying something like "with all this technology you would expect it to feel numb but it doesn't, it feels mechanical... it feels bloody fantastic"
just to add to that, i think he added the words like Analogue and Human
So many good quotes from that test that if he said uncool, that would be uncool!
Not a new car but a new yard stick
Analalogue
Human
A Million HP (TWICE)
Corners like electricity
When is the wall part being aired?
...and i agree on the Datsun reference being over done.
https://www.sau.com.au/forums/topic/229601-the-wall/page/2/#findComment-4041109
Uncool - if it isn't made in the EEC, its uncool, and he has that 'british is best' streak that he has to struggle against as well, so he thinks he's being more worldly by accepting EEC products.
One thing I noticed - He thought the Monaro/GTO/Vauxhall was good stuff before, now he is tending to rubbish it, so someone from Oz must have dissed him.
https://www.sau.com.au/forums/topic/229601-the-wall/page/2/#findComment-4044202
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
