Hi Guys and Girls,
Ok today i took my BNR32 to get tuned frist tune since i have owned my veicle,
I have a Power FC and my tuner hooked it up to the dyno to find out it's one of the frist Power FC to come out. The logging is diffrent and harder to read and there is no soft ware to update it. He can tune it but its going to take him double the time to get the tune 110% right.
Has any one eles had the same experiance with this drama.
Any feed back would be great thanks guys.
https://www.sau.com.au/forums/topic/229663-tune-power-fc/
Is it the first PFC he has tuned? All the hand controllers are in japanese in some of the screens
Not the frist PFC he has tuned, I dont have the hand unit so he just used a plug to read it on the dyno screen. And its in jap and he got no map to go of.
He knows how tune better then most people out there tuned heaps of 9 sec rbs. Plus he run rb engines in to the 9's with stock bottem ends and afthe the outtings the engine was still in perfect condition.
Wait untill he does my tune and ill post the dyno sheet up.
https://www.sau.com.au/forums/topic/229663-tune-power-fc/#findComment-4039543
Thats what i used for the first 2 years of tuning. Its a great system thats easy to work out.
If he has tuned 9sec rb's why havent we heard of them ?
Maybe you should get Godzilla motorsport to tune the car for you
it sounds like he is using an FC pro dongle with the japanese version of FC pro
there will be maps already present on the powerfc unit your car is running, so thats not an issue
https://www.sau.com.au/forums/topic/229663-tune-power-fc/#findComment-4040201
Its not that he cant do it, just takeing him longer because he cant go on live and every time he makes a ajustment it takes like 2mins to get the result. so it take's him alittle longer then normal. he tuned it on low boost 14psi so fare it made 250kw (25/60r turbos) and tomorrow he going to tune it on high boost 18psi.
https://www.sau.com.au/forums/topic/229663-tune-power-fc/#findComment-4041813
yeah it sounsd like one of the first gen PFC units, which has the slow logging and map update mode
it has to write every value each time you change the map - it cant just commit a single value change
Thats exacelly whats happening it's a pain in the ass.
https://www.sau.com.au/forums/topic/229663-tune-power-fc/#findComment-4041889
Finely i got my GTR all sorted out,
It made 268.3kw on 14psi and on 18psi it made 297.5kw just shy of 300kw.(still has standed pipes of the turbo's and cat).
But find out my transfer case is fu*k. and all the power just on the rear and nuffin to the front.
So i need get that fixed.
Post dyno sheet's up soon the printer broke so i didnt get a read out today.
Edited by Rav
https://www.sau.com.au/forums/topic/229663-tune-power-fc/#findComment-4044280
WTF ?? can you use those gen pfc's with datalogit etc?
https://www.sau.com.au/forums/topic/229663-tune-power-fc/#findComment-4044346
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
