I'm American. defense contractor and i live in japan. here are a couple quick snips of my R33. i rarely post here.
i bought it stock from osaka, had it shipped to my island. i'll list the mods if anyone cares:
17x9.5 Try force zelda +20offset with 20mm spacers (so they are 0 now)
boost limiter hose removed
boost solenoid grounded
hks velocity stack filter
JIC coilovers
5zigen exhaust
trust test pipe
hks ssq blow off valve
apex boost gauge
nismo white duracon shift knob
joined this site because i needed to find a country who got the skyline that spoke english and you cool-ass aussie people ALMOST speak english :wave: , i am a Mad Max fan, and i cant stand Brits, sooooo it made sense.
YES! triforce zelda's rock... well i reckon they do anyways...
might need to roll that guard a lil more and push the wheels out a touch more... maybe 5mm? you live in the land of perfect fitment... gotta fit in with the nihonjin.
are you on okinawa base?
I am on Okinawa, but I am a civilian and have a house in Gushikawa.
the picture of the rear is deceiving. its rolled, i just countoured it so its not rolled where it doesnt need to be. my limitation thre is lug length. i have the nismo long studs on there so either i need to go to a hub adapter or get different wheels. i want to get a set of gram light 57 psos and powdercoat them an obnoxious color like metallic tangerine because the make those in like a 12-15 offset so i would only need about 10mm of spacer to get them out there "lip to fender"
thanks for the compliments. i heard the aussies were a tough crowd like "the night rider"
3 Spokes Are The Perfect Thing... :) I also have Zelda Tripsokes.
I want to work on the fitiment on my R34:
the spacers are the cheap part. the tricky part is finding what mm tire to put on what inch rim. these are 9.5in with 215mm tires, i am going to go to 205mm tires but with a bit taller sidewall when i get these powder coated.
i jsut broke down and bought hub adapters on my lunch break so im going ot be able ot come out a little more in the rear so itll be perfect.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
