There was a non turbo model late in the cycle, but you'd have to import it yourself - not many would be wanting to bring in a non-turbo when there's an abundance of turbo's about.
But still, look for a post '96 model, type S like this one
180sx Type S
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4041379
just lie and say they dont exist :D will save for re-sale later and trouble of getting one here.. she wont know the difference and will just pick another hotted up car anyway and trade up to a 180 when she got full licence
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4042424
ive been mistaken many times when looking at the front of a silvia thinking its a 180
You sure your car is a non turbo..? Don't be mistaken but it is a GTS, right... ;):(
Yeah yeah just making fun, jokes! ;)
In relation to the thread topic, scotty180sx, it would be a lot easier if your g/f just bought a Nissan Silvia Q's.
They are quite the similar car.
If she gets a 1988 - 1989 model, the Q's will have a 1.8 L DOHC-I4 (CA18DE)
From the mid 1990's - 1991 models, they were equiped with a 2.0 L DOHC-I4 (SR20DE)
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4043340
Yeah, but they don't look the same. I'm guessing that's her prime motivation for getting a 180SX.
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4044697
well i give you a few scenarios here
you COULD buy a 180, source a non turbo low km engine, take the old engine out, undo all the intercooler works, undo the bolts to the front pipe, get a crane to lift the engine out, cut your hand in the process, get another crane, put the NA motor into the engine bay, bolt the engine up, realise you've lost a few bolts in the process, swear your head off, then when your gf comes outside to see whats wrong say it's got nothing to do with the car (that way she won't get mad at you for botching up her 180sx) then try to start the car and realise you forgot to replace the ECU then go on NS.com trying to find someone willing to let a NA ECU for 180sx go for cheap, wait for mail while your gf asks you what is taking so long while you make excuses like "there's a part coming" then plug it in and start the car and VOILA NA 180SX HOORAY
OR
you could pay a performance mechanic $1500 or so dollars in labour to replace the engine because they can charge that much because they have a "backlog n they dont wanna take bookings unless you got the dosh for it" and be told you can "feel free to take it to a regular mechanic but they'll take you to the cleaners mate im doing you a favour" and give him the car which he has for two weeks meanwhile you contemplate whether or not it would have been easier to do it yourself then your gf would think your tuff as cos you know all about carsnshit
OR
you could get over it and buy something achievable in the big scheme of things. rather than a 15-20 year old piece of shit.
WOW
THAT WAS THE BEST POST I EVER DID
HOPE YOU LIKED IT.
Edited by Mr Eps
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4044723
thanks heaps guys great info and yeah she wants a 180 cause she likes mine so silvias are out even tho i like em nearly just as much as the 180 but i have found one on car sales for around 10 so she better start saving her pennys
mr eps
what car do u drive if its anything other than a r34 a silvia s15 or a 99 180sx then ur car will b about the same age mate
scathing
spot on mate
thanks to everyone else who posted
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4045155
I see, so she likes the 180SX hatch back style.
Well try your luck in finding a N/A 180SX, OR get a turbo 180SX but keep it stock and scrub out the 'turbo intercooler' sticker at the back of the car and anywhere else and keep it on the low down. LOL!
Other than that I not sure what else there is.
All the best.
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4045193
The car's too girly for a girl?
I was going to suggest a Toyota Sera as well. It doesn't get that much girlier than that, but then girls look good in girly cars.
A Z32 is OK, but I think its a bit too big and the visibility out the back isn't exactly great either.
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4047664
have been lookin at gettin her a skyline n/a maybe instead till she has her full lincence and then she can get a180 turbo as there is heaps of n/a skylines out there i have even found a few r34's out there. she wants something that looks hot guys forget about the nx or exa we want someing a bit new and that still has some balls.
https://www.sau.com.au/forums/topic/229964-180sx/#findComment-4051715
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
