So i got my brand new power fc for my car today. I hooked it up but i get a ticking from the reley near the battery. I also get a ticking from my boost solenoid. The ticking from the solenoid goes after 10 secs but the from the back its still there. i read that r33 gtst's sometimes have a voltage problem getting to the ecu so i hooked up a contant power wire to the constant power wire on the ecu to help with the voltage but that doesnt fix the reley ticking. The check engine light also flashes quickly for 10 secs but stops when the boost solenoid stops ticking. Ive disconnected the solenoid to stop the ticking but the reley at the back still ticks. On the hand cont it goes past the apexi logo to the menu. But it goes blank (backlight still on) when i get to the 'function' setting to try n disable the boost cont setting, so atleast i know the unit is suited to my car. Ive read Paulr33's FAQ's but dont get an answer for my problem. Can anyone help me please????
https://www.sau.com.au/forums/topic/229981-power-fc-problem/
for that level of operation something is horribly wrong
ticking relays is a sign of damaged components usualy
along with flashing engine check light something is wrong dude
i would undo main battery terminal - un-install powerfc, re-install stock ecu
confirm car runs as normal and no wierd shit (start it etc)
then if all well put the PFC back in turn car to ACC but dont start it
check normal hand controller operation etc
then if all ok start it (or better yet do DATA INIT before you start the car - its in the FAQ)
anything is possible - smell the PFC, can u smell any burnt items? open up the case and look for burnt tracks/components
put the PFC back in and turn car to ON but dont start - see if the hand controller works normal
That was the first thing i checked. There is no smell, i opened it up just to make sure - no burnt tracks. I can use the hand controller but i have only gone to try and disable the boost cont setup as advised in your FAQ, i get to 'function', go into that and thats where the screen goes blank but still with the backlight on.
on the back of the unit - seriel num ecr33 010-2486
hand cont - fcc3 020 - 26527
i rem on the screen it comes up with version 5 . xx
i have my stock ecu in now, i can hook it back up to get the version if it helps
i can get my hands on another one soon(1or2days) so ill hook that up to see if its the unit or if its the car. Ive givin up 2nite, to cold outside. Ill wait till i get the other one and see what happens with that and keep you posted. Thanx for your help
Have you tried the below section of the FAQ? I had a similar problem which was driving me nuts as everything appeared to have the correct voltages etc. When I first looked over the fuses they all seemed fine. What I didn't realise is that I was missing a fuse in the required slot. I put the correct sized fuse in a no more clicking.. I'd be double checking this as it takes little effort.
Good Luck.
My car won't start when I plug in the PowerFC, but the stock ecu works fine
First when dealing with a new PowerFC install and the car does not start there are a few basics to check;
Check the PowerFC to car loom connector
Check the warning lights on the dash, do they come up?
On the hand controller, goto ETC, SENSOR SW CHECK, are any sensors highlighted in black? (Shouldn't be)
Make sure you disable the Boost Control Kit if you aren't using it
Make sure you have the right airflow meter selected (if you have a non standard one)
Make sure you have correct injector settings (if you have non standard ones)
Check all fuses
Listen for clicking relays
Check for burning smells near the ECU and or inside the ECU
Inspect the ECU itself for physical damage or burn marks (open it up)
Finally we have seen on a few skylines that the car works fine with the stock ecu but not the with PowerFC. It has been traced back to a missing fuse. The missing fuse is on the left side in the R33 GTST and its at position #7. According to the diagram it is Engine Control. Somehow the stock ecu works if this fuse is missing but the PowerFC doesn't
See the diagram here for "Engine Control" which is a 10AMP fuse.
Edited by Fry_33
So when i first had this problem i checked for the fuse in the position stated (7), it was there, but there was a missing fuse beside that. I put a 10 amp fuse in that spot (on the fuse cover it says its for the batterty) and guess what.......the ticking stoped and now im up and running. I finally have it working :) . Thanks people for the help.
Im 1 happy chappy!!!
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
