use the 32 cas swap the exhaust cam swap the diff
+/-1g weight balanced pistons & conrods
Thicker piston second land (std: 4.0mm N1: 4.6mm‚Ö)
Reinforced con-rod bearings
N1 water pump (improved flow & less cavitation)
Reinforced cylinder block head bolt boss
Narrowed distance between two piston rings (std: 1.5mm / N1: 1.2mm)
Revised camshaft profile (exhaust overlap: std 0 degrees / N1 5 degrees)
N1 oil pump (higher flow rate)
Increased sump capacity (im not sure about this)
weight 217kilos
Edited by spilmer
Mine should be here soon :D
did a similar thing with my 32, N1 r33 pistons cracked #6 or broken rings, still block not out of car.
As said use the r32's cas, and i think there are a few other plugs, but just use whatever off your 32 motor on the 34 one.
everything above looks good, tho i think the sump is the same as standard?
I'd like to know if it would be worth balancing the bottom end again tho?
i am thinking of leaving mine stock and just balance, ati damper, oil return and oil restrictor.
Guys,
My motor died & a brand new NUR R34 motor appears to be an option.
Question 1 - How does one modify Cam Angle Sensor to accept my R32 wiring?
Question 2 - Does the NUR motor have forged N1 internals or just the N1 block?
Hi there, I don't think they do have forged internals (pistons) but like others say there are other significant improvements, plus you have a factory assembled engine. With an ATI balancer you should have most of it covered for some hp fun. :down::ermm::P
Cheers GW
PS: Thankyou Importmonster & the ATI group buy organiser.
Here is a bit on the N1 motors, came from the Wikipedia site.. http://en.wikipedia.org/wiki/Nissan_Skylin...E2.80.932002.29
From what I can Gather is they are hand built.
Hope it helps. :P
[edit] N1 engines
The RB26DETT N1 is an upgraded version of the standard RB26DETT engine. It was first developed by Nismo for Group A racing purposes. The standard RB26DETT, although known for its durability, proved to require too much maintenance for Group A racing conditions. The N1 engine is built from the standard RB26DETT block. The water cooling channels in the block are enhanced to increase flow. The block, and internal components are also strengthened. The pistons have 1.2 mm (0.047 in) top rings, but otherwise as standard. The connecting rods are the same as standard, and the crankshaft is standard but balanced. The specifications of the camshafts were also improved for power. The N1 engine uses the same parallel twin turbocharger layout but with improved turbochargers. The N1 engine also received an upgraded oil pump and water pump, to improve the cooling and lubrication of the engine. The N1 engine is identified by its 24U number stamped on the block, as opposed to the 05U stamp on standard RB26DETT engines.
The first model of the N1 engine was the R32 N1 engine. It uses a pair of larger turbochargers compared to the standard R32 GT-R. The turbine wheels on the new turbochargers are made from steel, rather than the weaker ceramic used for all standard GT-R models. The R33 N1 engine was slightly revised, with larger turbochargers than the R32 N1 engine, supporting more power if the engine were to be modified.
The R34 N1 engine saw further improvement. The camshafts were slightly improved for even more potential power, the turbochargers were about the same size as the R32 N1 turbochargers, except now they use ball bearing technology, which operates much more quickly than any other model used.
The most improved N1 engine is the R34 Nür engine. It is based on the R34 N1 engine. The camshafts were further improved for power, and the crankshaft was further balanced for higher engine speed. There were 1000 Nür engines made for use in the R34 V-spec II Nür, and R34 M-spec Nür models, however an undefined amount of extras were made and sold through Nissan dealers. They were advertised as making the same 280 PS (276 hp) as the standard model, but with the lighter engine parts, and more efficient turbochargers, the engine would make closer to 350 hp (260 kW).
Edited by 1Fatman
I have a question regarding the diff in the 34 motor,
actually i dont. i think my 34 n1 motor was in a r32. so the front diff should be fine...
how do i make sure of this?
Also.... if i was able to pump around 400rwhp + out of my r32 motor that had 33n1 pistons.
what can i push out of the 34 N1 motor?? should i be able to get somehwere near a safe 500hp at the wheels?
Edited by Angus Smart
so do you have to change the exhaust cam to fit the R32/R33 CAS? is there anyway round this? just thinking it would be better to keep the N1/NUR cams.
are 34 cams any different from 32 ones? i thought all i had to change was the cas depending on which cams i wanted to use.
tho i think my Used motor was already in a 32 and comes with 32 cas/cams. and also already has cams too apparently.
i still wouldn't mind knowing is its a good idea to get the bottom end balanced on the 34 n1 motor. or is the factory job good?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
