and I bet the powerfc is tuned for full power only, and none of the cruise, low or medium load have been touched.
Thats what tuners do these days, on the dyno, do the full power curve, and then charge some poor prick $800.
mate it very wel could be the tune, but i dont think the person who tuned it wouldnt have taken his time doing it properly. it was a reputable workshop. and the car was tuned last about 6 months ago. and hasnt had any new modifications. plus if it was the tune, why would it have been fine for the last 6 months, and only start fowling plugs in a day, after the last service?
only thing, other then the fuel pressure reg (working fine), that i can think of that could cause this sudden offset is the new o2 sensor? but can a o2 sensor cauz plugs to fowel up that bad?
will have a look for vacuum leaks. however, cars idle is stable and doesnt miss (prior to fowling plugs), and holds boost fine
ALso, i discovered i had a tiny hole on the hose going into the fuel filter, which i have now fixed. any chance that could have contributed?
yeh this weekend, im gna borrow my mates afm and o2 sensor, and see if the spark plugs fowel up. if they do, then ill book her in for a touch up tune on monday. just wanna eliminate all possibilities before i spend money at a tuner
Don't mean to sound like a tosser, but what do the plugs look like? Been around since T-rex, but check this. Take a pic of your plugs, post it up for comments.
From my experiences, plugs in a modern car have to be obscenely dirty to cause a dodegy idle, maybe tis something else.
Edited by GeeTR
so the regs not holding pressuere by this statement or is holding too much
Does it blow a cloud of smoke on idle if you free rev once warm?
If so, fuel reg is 99% the culprit :(
Just get another and off you go.
Can also be checked when driving if you have a fuel pressure gauge and feed it out under the bonnet
OK WELL ill explain exactly what happened today. i instaled new plugs and changed the o2 sensor. car was driing/idling fine, no misses etc. as soon as i gave it a hit on high boost (0.9bar). few streets away from mine. when i parked the car, it began to miss on idle (all plugs fowled again). im heading towards a tune issue, but i wanna cover al other possible culprits, so i dont have to spend too much money at the workshop, incase its not tune related
you guys were right, it was the tune. it seems the previous tune was tuned for the faulty o2 sensor, so when replaced with the new o2 sensor, it ran extremely rich and kept fowling the plugs. got a retune done today and all seems to be sweet :P
thanks for ur help, greatly appreciated
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
