hi guys im looking at buying a skyline within the next 2 weeks and need advise on which car to buy.....
im looking at 2
the first:
1994 NISSAN SKYLINE ECR33 GTS-T
with......
- TRUST FRONT BAR !!!
- MICROTECH LT8 COMPUTER (needs re-tune)
- 3" JJR DUMP PIPE STAINLESS !!!
- 3" HIGHFLOW CAT MAGNAFLOW !!!
- 3" Trust Power Extreme II Exhaust Stainless !!!
- FRONT MOUNT INTERCOOLER !!!
- ZEAL ADJUSTABLE COILOVERS !!!
- MANUAL BOOST CONTROLLER !!!
- APEXI TURBO TIMER !!!
- MULTIPLE POINT IMMOBILIZER / ALARM !!!
- 19" BSA CHROME WHEELS WITH BRAND NEW RUBBER!!!
car also has 11 months rego and looks good, but he has never had in on a dyno.. cost $10,500
skyline_10.500.html
the second:
GTS25T.M/LSD active LSD model
ADAPTRONIC e420c fully programmable engine computer***
HYBRID front mount intercooler...
X FORCE 3" stainless steel exhaust system with 4.5" tail pipe...
WALBRO in tank 500hp fuel pump...
SPLITFIRE high performance coils (6)...
Titanium long life spark plugs (6)***
SUSPENSION enhancements are KYB rear shocks, WHITELINE adjustable front end radius rod bushes
car has 8 months rego and has been dyno at 195 kw... cost 12,000
any advise would be great, as im not quiet sure what to do??????
thanks
kyle
https://www.sau.com.au/forums/topic/230502-which-one-to-buy/
Both pretty similar in spec from the looks of things, as in both have exhaust, 'cooler and some type of ecu and some suspension mods.
So not much in it as far as difference in mods.
Niether apear to be seriously worked on.
Go drive them both, and get both inspected by a mechanic you trust, then make a descision.
All we can do is say if the mods are good or not. And its never a good idea to pick one car over another just because it has more modifications. Compare the overall cars, condition of paint, interior, engine health, ride quality, gearbox etc, then make ur choice.
On appearances alone though i'd lean towards the Black one
As much as I dont like it..
My 2cents is the first one..
In all bases its better modified..
If you want a track car.. its got coilovers.. ECU..
if you want "bling".. its got that too..
And your saving 2K
And according to all the exclimation marks.. I think you too have made you decision..
Arent the Active lsd only on the series 2's? Even though it has more mods i dont like the look of the R33 series 1 interor and the bonnet + lights. + ide go for the newer car and the one in better condition.
More mods means more thrashed, no one builds a fast car to drive solwly. Regardless before you buy make sure you get it checked out by a mechanic.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
