hey, just wanted to get some info on a front conversion kit from stagea to r34 gtr. i know the company masa motorsport make one! but i want to know if i can buy one in aus. and if so, from who and how much? also does anyone else make them? i want one with a front bar as close as i can get to the factory r34 gtr as the masa one is not close enough! cheers for any helpful information!
https://www.sau.com.au/forums/topic/230711-stagea-front-conversion-to-r34-gtr/
i have a origional r34 gtr front bar new from nissan, still wrapped in plastic and unpainted comes wif all bolts and brackets. does not have front lip as its an extra option from nissan. pm me if your intrested
hey not after std r34 gtr! needs to fit stagea but look as close as possable to the original 34 GTR! cheers!
Do a search of the stagea section
I have done the conversion
Will set you back approx $4500 in parts plus labour and painting
My car will be for sale soon series 2 manual etc
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
