do a search mate, this topic has been posted a thousand times before .... Iron Chef, Prestige Motorsport, Redline, JSpec .... do a goole search and you will find many more ....
15 year old rule... have u looked it up?
what u mean?
i think she means that the rule has changed, it not the '15 year rule' anymore its more the 1988 rule therefore no more GTR's can be brought in cheap they have to have full compliance!
it would be better to find a local car so it can be test driven comp checked ect
better off finding something which has had a rebuild. theres a few good examples in the for sale section
or +1 for Iron Chef Imports
Edited by shy_s6
I got my R32 GTR through Iron Chef, best to email Kristian to work out your preferences and he'll go through all the jap auctions and contact you when he finds R32 GTRs that match your preferences/price range.
I'm gonna kind of go against what everyone has said a bit here, but the fact is that we import brokers all pretty much do the same job, so from that perspective, the big guys like J-Spec and Prestige are presumably doing a good job or else they wouldn't be in business. I don't really count myself in their league just yet!
I did some quick calculations and worked out that only about 40% of the cars I buy actually come to SA owners - the rest are sent all over the country - and the only reason I mention this is because, apart from your own peace of mind, it doesn't really matter where the broker is based.
One small point of difference is that I regularly head to Japan to find cars for customers, but most brokers will have agents there that they trust to do the same thing, and I probably 90% of all the cars I buy through one particular company because I trust the buyer's judgment as much as my own. My customers will know that this often means having to wait a long time for the right car to come along!
Probably 99% of the cars I buy are bought to order and are never put on the site - the ones on the site are usually stock that agents have in Japan, often as a result of customers pulling out after a car has already been bought.
With importing R32 GT-Rs make sure you have a good budget, as they are going up in value over there, and if you're thinking mid-high teens, best off looking locally, rather than risking getting a crappy one overseas, where you can't check it over or test drive it. A case of "better the devil you know"...
Oh and thanks for the kind words, guys :D
Edited by Iron Chef
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
