Thought id share some pics of my new toy, its a tony kart thats been lengthened 40cm with a gsxr750 motor. I used a calliper off my lancer and a clutch mastercylinder off a silvia frontcut for the brakes with a braided line i had made up. The throttle and clutch cables also had to be made up. This is the first attempt and there are a few small things im going to change to make it better, first thing will be the gear ratio. In 3rd you let the clutch out give a bit of gas and it fries the tyres. Had some trouble getting it to run good with the short exhaust on it and the free flowing air filters it was running extremely lean on the main jet, so far we have drilled them out to 2mm but its still got some more left to go. Im thinking of putting the t25 turbo from the front cut i got on it later but gotta finish my lancer project first lol.
post-21010-1217752842_thumb.jpgpost-21010-1217752864_thumb.jpgpost-1482-1124373157.jpgpost-21010-1217752908_thumb.jpg
https://www.sau.com.au/forums/topic/230753-my-new-toy/
Looks awesome. a mate built one similar, they are really a bit silly, there is no way they put any power down, it will still be wheelspinning at 140km/h regardless of what gear ratio you put in it. Just be carefull, the shorrt wheelbase means that they are keen to turn around, and at 100km/h they can step out and flip in about .1 second.
https://www.sau.com.au/forums/topic/230753-my-new-toy/#findComment-4053704
Looks pretty cool Russell, i used to have a shifter kart with a ducati 848 motor - V-twin FTW :google:
Its an interesting set up, i take it the motor is a pre 98 750 motor???
Yeah its a 93 model motor. Burnt a new set of tyres off it today and its unreal fun but tyres dont last long enough.
Where did you run your kart at?
https://www.sau.com.au/forums/topic/230753-my-new-toy/#findComment-4064080
:( yeah tyres dont last long when your having some fun with these things, probably one of the only downsides really.
I ran mine of a couple of karting tracks here and also took it around Baskerville (full race track) for a bit of fun as well. It did see the "occasional" street use but was always out of well established housing areas so we didn't annoy anyone :)
Gixxer kart is cool, my first shifter kart was powered by an 02 gixxer 1k motor which i sold so i could build the 848 (V-twin FTW :( )
I'll try and dig out some pics to post up :D
https://www.sau.com.au/forums/topic/230753-my-new-toy/#findComment-4076825
hehe.. man that is seriously over powered! can I have a go?
I'm building a off road buggy with a 1.3L in it... should weigh in about 350kg (if i can keep the weight down, also depends how much i can strip off the engine!) Wont be as crazy as that little machine, but will feel like it on dirt!
Good on ya!
Edited by psi
https://www.sau.com.au/forums/topic/230753-my-new-toy/#findComment-4084954
  • 3 weeks later...
:laugh: yeah tyres dont last long when your having some fun with these things, probably one of the only downsides really.
I ran mine of a couple of karting tracks here and also took it around Baskerville (full race track) for a bit of fun as well. It did see the "occasional" street use but was always out of well established housing areas so we didn't annoy anyone :D
Gixxer kart is cool, my first shifter kart was powered by an 02 gixxer 1k motor which i sold so i could build the 848 (V-twin FTW :P )
I'll try and dig out some pics to post up :thanks:
This is my toy that i have created.
2005 model yfz450 atv with a 2006 model zx10r engine.
ive had it to 230 kph across a paddock several times, and
also 160 kph wheelies are a breeze.
have a look on youtube under yfz10r for some vids.
so grandmasterb tell me more about the ducati 848.
im looking for that exact motor for my next quad.
where did you get one from and how much was it?
pm if u like.
https://www.sau.com.au/forums/topic/230753-my-new-toy/#findComment-4130996
pm if u like.
Looks like a pretty wild conversion Darren :dry:
I purchased a written off 848 to pull the motor/box out of to use from auction. I had actually one out there to bid on something else but then got crazy thoughts when i spotted it :huh:
I was lucky that no else bid on it so it only cost me $1300 which i couldn't really complain with as there were a couple of other things that i sold from the bike that were still in good condition :bunny:
https://www.sau.com.au/forums/topic/230753-my-new-toy/#findComment-4135589
  • 2 months later...
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
