I found a few other threads but they werent very thourough, i just want to compile a complete list of what should be done, so far i can think of;
Water pump
timing belt
tension idler
spark plugs
fluid flush
oils
do other things generally get done or do you need them such as;
fuel filter
timing
seals
or are these the type of things you only fix when they're broken ?
help or input is much appreciated :blink:
https://www.sau.com.au/forums/topic/230801-100000km-service-to-do/
Im also coming upto 100k and was about to start looking around for a list of things so this will be a big help for me :blink:
So far ive got all of the fluids, coolant, spark plugs, oil filter, still trying to find the part no for a fuel filter.
Would it be a good time to do break fluid? or is it not really needed
Yeah im up for the 100k service very soon also..
Will be doing everything listed in this thread and then some, since im prepping my car for track (turbs, brakes & weight) I will changing most of the gasket's, new pads + lines and brake fluid, cleaning out cooler.
Basically doing everything i possibly can.
^^^ On top of these items, I'd at least check the fuel filter & clean it out. It's situated in the fuel tank via a stalk on my car. Just Jap and others have a few quite often.
For race tracks, it's a good idea to check minimum width and condition of brake rotors. When at a minimum and with heavy braking, they can heat up all of a sudden (which is a bit less of a problem when it's for road use only). Brake fluids are worth changing especially if the car is left standing for periods without use, since they can absorb moisture from the air at low temps.
Check bushes, drive shaft boots too.
Cheers, T
100,000 K's, it's one of the big ones.
So change,
Oil
Oil filter
Air filter / Clean pods
Fuel filter
Battery (If you think is getting old)
Radiator Coolent Flush
Brake pads / Machine Disks (If worn)
Timing Belts / Fan Belts
Spark Plugs
Check all your tyres (Change if worn)
Gear Box oil (If had not been done)
Check under the car / drivetrain
And do the genaral service look over.
Thats mostly what I can think of.
I'm also coming up to my 100,000kms service.
Have been told timing belt, tensioner, tensioner bearing, water pump, coolant flush and at another place some other things too.
Any mechanics out there who feel like throwing a quote with parts and labour included would be absolute legends.
God like in fact :D
Changing the timing belt would probley cost $300 $400 tops. Give or take (Approx)
If you do it yourself, make sure you put the belt on correctly and must be aligned perfect. Other wise you can alter the timing and your car will be out of wack = loss of power and car runs shit.
I was not there to see him change it, otherwise I could tell you what to do.
No need to change your cam gears. Only do that it you want to race the car and/or adjust the angles of the cams open and closing.
for those of you who are saying should the fuel filter be changed at the 100k service.... well i hope you change it atleast every 20k.
some other things to consider...
Engine oil
Oil filter
Diff oil
G/box oil
Wheel bearings
Radiator coolant
Water pump
Thermostat
Air filter
Timing belt
Spark plugs
Brake fluid
Clutch fluid
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
