there are only 2 tuners in aus for hks f-con, as my mate has just got his front cut from jap with a f-con, there is one tuner in WA and one tuner in sydney, so if you live any other state it sucks as im sure these are a well built system, apparently there is a fair few problems with after market comps and them working well on auto's, but i cant reccomend one as i really dont know,
WTF ?
The emanage blue does a great job for what it is. Have you actually tried one ?
Whack the emanage on, someone who knows what they are doing will be able to get the car running great! With the Auto i would only suggest a emanage for anything thats not totally worked off its head, and even if it is.. go the Ultimate
agreed, i had a emanage blue tuned on my evo 6 & it drove great & made excellent power. little bit more than a evo 6.5/tme with slightly more mods & autronic. both tuned at asg in perth too.
OK, heres just my 2 cents.
You need to ask yourself these 2 Questions!!!
1. What are your power goals (200kw, 250kw, 300kw???)
2. Are you going to mod your car any further in the future?
These come in to factor of which ECU will bring out the full potential from your car and thus presenting you with your respected goals.
So here I say...find out what your typical goal is
Also what comes into perspective are
- Budget
- Reliability of engine ie. 300kw you will be lookin in investing further with your engine eg.bottom end.
So tell us these and i'm sure we could head you into the best direction
Cheers.
RJ
hey all just wanna know what the best ecu for a auto r 33 would be as im not too happy with the emanage blue capabilitys for tunning..also how much all up tuned thanks ppl
Give Hanson at XSpeed a call as they have some of the toughest Skylines in WA. His number is 08 9331 8088. He can even supply and fit a F-CON iS or the F-CON V Pro which both have automatic shift control.
I can only contribute to a process of elimination...
I have a HKS F-Con Pro-V but I can't recommend it because the expert tuner from Japan only comes here periodically;
despite it running well. I can't touch it!
Cheers, T
Seeing as you are close to Sydney I suggest you call Jim at Tunehouse. They have been appointed as the HKS Pro Dealer and can tune your F-CON computer. His number is 02 9557 4000.
You can also get this info from www.hks.com.au
Cheers
Marty
powerf fc's become too fidley at high hp/big airflow and 2 blokes i know have gone haltech with massive immediate improvements
both have gone from troubles in the low 400 hp with the power fc to 470hp and 510hp at the wheels with the haltech (510hp with rb25 and 470hp with rb2530 both with gt35r)
What kinda trouble are they getting?
There are easily 30 cars i can think of here over 350rwkw running PFC's without a problem (nismo AFM's in, off you go), be interesting to hear what the problems are that the people you know are having etc
tripple posts ashie lol
both cars have been 'home built' and tuned by the 1 tuner (both for the power fc and haltech). both have been tuned by the 1 tuner for max power and both have encountered similar problems with the power fc and both h ve only reached potential with no afm's and a haltech
the 510hp car made 503hp early on with the power fc but later on had mega issues & as explained (in above posts) and was easier to go to a MAP based ecu. and since both cars have had 0 issues, multiple track days and drag days later
hi 5 to autoworx
in the market for ecu myself soon
glad their is progression in aussie ideas!!
keepin it local!! :domokun:
i do like power fc comments though still undecided :domokun:
get the vipec from Alistair @ Autoworx and he will arrange lumpy to tune it refer W.A. section about the ecu
i have the first one in the state in my gtr and am really happy with the results
Cheers, T
Hi Terry, sydneykid tells me that he knows a guy who is currently being trained to tune the F-Con Pro-V and he will be local too. If you check with sydneykid he can give you the exact details.
Interesting - do tell more!
SydneyKid - Care to elaborate on this?
Cheers
Marty
Hey guys sorry to hi-jack the thread but i wondering what my best options are for an engine managment system as i running the stock ecu atm.
Car: 1995 R33 GTS skyline
Engine: Rb25-det
KKR480 Turbo
Apexi D1 dual panel pod filter
HKS SSQ bov
Hybrid FMIC with alloy piping
Greddy oil catch can
JJR Anodized red boost controller
Red silicone piping
Gear box: gts-t 5 speed manual box with heavy duty clutch
Exaust: Otomoto Dump pipe, Stainless Nismo Front pipe and 3” exhaust from cat back with super-cats Australia resonator
Why wont people understand that it all comes down to the tuner??? "Oh i just put a microtech in my car and it runs shit" its not the god damn computers fault the computer only does what its told to do! And the person who tells it what to do is the tuner!
thanks for that imput i understand that the ecu is only as good as the tuner just wondered what would be my best option for the modifications i have. i am looking around for a power fc atm. as i understand they are reasonably cheap, reliable and easy to tune and would support my modifications, hame
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
