when i first got my car i blocked off my valve and was running sweet for about 3 months, then i changed over my spark plugs then it started to stall sometimes and sometimes when the revs dropped from really high to idle. I just made it out to be a tuning issue but when i put new turbo and engine mods on and it stalls without fail every time if you don't keep fairly high revs. The guys that are tuning it are telling me that i can't block of my blow off and that i have to run it in order to stop the problem, but i don't want to do that. Pretty much everyone i know with a turbo has blocked theirs off, just wondering what could be causing mine to stall when i block mine?? i got an rb25 by the way.
ahahah classic thread with great responses.
The hektic flutterz is awesome bro i just had to get a new turbo cause my old one died mysteriously...wonder what could have done that.
hhhmmm i wonder why they put a bov on from factory??!!? :P
This has been posted plenty of times - you should search the forums before posting.
Your car has an AFM. Your tuner was correct in stating that you can't do it if you want to stop the problem. Once the air has been read through the AFM and you release the throttle thereby closing the butterfly, the air returns down the intake pipe trying to find the BOV and recirculate. That is what it should do standard.
But you have blocked the BOV so the air goes back out the turbo the wrong way (or at least attempt to) and you get a stiffy as you flutter past teh laideeez and bro's (probably just the bro's) at maccas.
Problem is, your ECU has read the air going into the motor, but it hasn't and it dumps fuel in to keep the AFR correct. Thus flooding your motor with fuel and stalling.
There are numerous way's to get teh flutters without stalling, smartest one being geting a new ECU that runs a MAP sensor instead of an AFM. But since you probably wont...........you deserve the crap that you already have and will continue to get on this subject.
Good Day Sir!
Agreed, Air Flow Meter (AFM) is reading plenty of air going into the motor, adds fuel to mix, none of that air is making it to the motor, floods the motor...
How is your fuel consumption?
Sorry for the attacks, but it happens every time... you should have a done a search :P
Hope this does help.
ZOMG BRO! i luv da full hektik sik dose uleh!
bro... i put da afm in my interkooler pipeing right... den put a pipe into my full hektik ebay t3/t4 turbz wif a 90deg bend and some mesh ovah it so da dose is like full sikk loud!
da chikkies luv it bro!
every 6 munfs when my VL is actually running i go down for chap laps and i get da mad pussy! dey like full flock to da car!
dey luv it bro....
hey, bro, see dat bitch ovah dere... she wants me bro...
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
