Reading all this has got me thinking that i should try to get my turbos on before this event so i can get over the 300kw mark aswell. I'll make some calls tomorrow and see what i can organise :)
  • Replies 281
yeh come join the 300rwkw club Chad....lol
Just buy a heap of G size bottles... and while the import cars are running, open all the bottles into the dyno cell - extra power and a nice relaxed and cheerful mood for everyone :D It might cause a fire, but that just makes it easier to cook the BBQ food.
Ken/PIMPED, 400rwkw using 550cc Sard injectors... that's what i call pushing the limit!
I'm going to do my best to make it to this dyno day, as it sounds really interesting. It'll also be interesting to do a rough comparison (power curve, peak values, turbo response etc.) with my own dyno runs on Shaun's dyno - there's about 90+ of them saved on the thing ha-ha.
I might even have the tuning finished by then and could try and help bolster the import figures - I 'may' be able to offer low 300's at the rears - best of 302rwkw so far. It might squeeze out 315-320ish once the cams are set-up and a few more pounds wound in.
What we - the import team - really needs is for Darren's R31 to be up and running - 550rwkw would help push the total up nicely.
yeah im abit worried bout that atm, going to 1000cc soon, but i hope the 550cc will hold out for 400, fingers crossed anyway, but it makes 300 with easy, fuel is running really rich atm, was told rich enough to get almost 400rwkws with but i would be pushing it, i dunno, ill get it on the dyno and see what we can do, and the remap of the 32 ecu is wicked, better then my power fc in my old 33
Edited by PIMPED_jzx100
Nitrous oxide is not flammable.
Correct. Oxygen is nonflammable too. However, what these gases are very good at is supporting explosive combustion, all they need is an ignition source and a saturated concentration - think dyno cell full of G size bottles opened fully and then add a red hot manifold. I'll be the one standing over the road :P
Next time you're at the drags and you see someone purge their nitrous system, don't stick your head near the stream of purged N20 smoking a cigar... unless you want to look like Micheal Jackson :O
I guess it depends on how 'real' those 400rwkw are, if you get my drift. To safely support a genuine 400rwkw you are going to to be pushing well beyond the safe level for 550cc injectors. I wouldn't risk it. Wait till you get the 1000's in.
just grab some NOS and spray it into the intercooler MRVLT style.
hahah yeah that was the funniest thing to see on the autosalon dyno
they could have just used fire extinguisher
it would have done the same job lol
even funnier the power figures didnt really improve though lol
Using LOX (liquid oxygen) would 'kind of' work nicely at externally snap cooling the intercooler :)
I can't recall the exact LOX temp off the top of my head (- a few hundred 'c) cryogenic freezing temp's that's for sure. It also has an expansion rate of 600ish to 1, as in 1L of LOX = 600L of gaseous oxygen. So watchout when it reaches a source of ignition! Great for speeding up the BBQ cooking times, it'll cook snags in microseconds, then melt the BBQ and burn a nice hole in the ground under it :)
Anyway, back to the dyno day conversation. Any info' on the domestic entries?
hey buddy who did u get to remap your 32 ecu??
jeff at turbotune, did a good job, isnt cheap for most people though, lol, also i wont be boosting her up anymore, keep her at 300rwkws, 550s wont hold out, it will lean out to much, 20 psi is pushing it with them, so 16 psi will have to do, will still be in the 300rwkw club though, if there is such a thing? lol, hope to see u all there
Good move mate, as it's just not worth taking the risk. Get those bigger squirters in there first, then you can crank up the boost safe in the knowledge the fuel system can support it.
We are both at a similar point actually, as I'm just about to upgrade to a new set of 780cc injectors in my 33 - my 550's are no longer up to the task... especially for E85.
so urhhhhh what are you going to be doing with the 550cc injector? :O
Ha-ha, yep, I'll be selling them. However, one potential problem. I have a custom top-feed fuel rail, which means my 550's won't suit the OEM RB25DET rail.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
