I'm Goin For A Drive *sunday 7th September*
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 186
Posted Images
LOL yes the paseo chick.... Haha I'm just the rude bitch that cut her off... But seriously woman get out of my way!!!!!!!!!!!!!
I nearly forgot to mention it, did u guys see the police car on Commonwealth Ave bridge that had just pulled some dude over? It's lights were hidden in the real ones or something, never seen one like that before!!
Yep, there's a few undercover cars like that. Gotta watch out :| The next slightly more obvious ones are those with the lights set in the dash (at least it looks like that to me). I guess we were also lucky that the only other popo we/I saw was going the wrong way and that was near the end of our drive.
yes wonder where that cop was going........
Kat, yeah I've seen lights like that before, seems like they're literally "built in" to patrol cars these days lol
Well then.... I think thats a bit harsh! :P
And here we were protecting poor little molly from the bad park rangers..
But i'm sorry... i won't invite any more paseo drivers.. promise!! :)
awww Molly wubs you all!! :)
  • 2 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
