hey
i want to buy a r32
ive been looking around iand ts hard to find a non turbo one and when u find one there more expensive then the turbo ones
how hard would it be to buy a turbo r32 and take out the turbo and how much would it cost to do
i would have to replace the ecu with a non turbo one and get a non turbo inlet and outlet manifold.
any advice would be really appreciated
thanks
https://www.sau.com.au/forums/topic/231193-removing-turbo/
If you do the work yourself it shouldnt be too expensive..
You need;
Intake piping
Exhaust mani/Headers - I have a stock exhaust manifold if you are looking to buy.
NA ECU.
Now the problem is compression ratio. The last thing you want is a low compression 2L NA.
You could always take off the head and shave the balls off it to get the NA 10:1 C.R. Or shave a little more and run a higher CR to give it more poke. Say 11 or 11.5:1. I figure if your taking off the head you may aswell.
Thats about it.
But why buy an NA R32 when there are so many better NA options available?
https://www.sau.com.au/forums/topic/231193-removing-turbo/#findComment-4060454
The compression ratio of your RB20DE-T (as well as various flow characteristics of the cams etc, which I don't know is the same between NA and FI) isn't your only problem.
The gearing is completely different between the turbo cars and NA, so even if you pull apart the engine to increase the compression ratio and get its efficiency close to NA, the thing is still going to run like a dog. Theoretically you could just replace the final drive and leave the gearbox itself as-is and you'd get most of your performance back, but there's another expense.
For the cost of doing what you want to do to an R32 GTS-t, you could have bought a good car.
Also, its also debatable whether its legal for you to drive it. Some people have called the RTA, who've said its OK to take the turbo off, but a guy I know called the RTA who told him it was OK to drive a 350Z on his P's without an exception, even though its clearly marked in the banned list.
The wording of the rule is that P platers cannot drive cars where the engine performance has been "modified". Note, it doesn't say "increased", just changed from its factory specification. If your car is meant to have a turbo and doesn't, the performance is no longer the same as when it rolled off the factory floor. A "letter of the law" interpretation says the car is therefore still not P plater legal.
If a cop's in a bad mood, its a reasonable interpretation as an excuse to ruin your day.
https://www.sau.com.au/forums/topic/231193-removing-turbo/#findComment-4062191
I don't know about 32s... but 33 na's I believe have slightly lumpier cams? don't quote me on that though. also, as everyone has already said... compression ratio... not to mention the pistons will be a little bit of a different shape as well... the turbo ones have a lump ontop and the na's are flat..(also from memory)... to be honest... its not worth it.... you will be spending that much money for absolutely 0.
if you do do it.... and you don't increase compression and all the rest of the crap... excels will flog you... it may be nice to say you drive a skyline.. but driving it would be horrible! just wait till a good na comes around. you will be much better off... or look at na silvias... 180s.... 200s... dont just limit yourself to one na import :P cuz there are heaps of other na imports!
Adam
https://www.sau.com.au/forums/topic/231193-removing-turbo/#findComment-4065687
  • 4 weeks later...
i was looking at the same thing too but with a r33 cuz i want to put the turbo back on when i get my full licence..if money is not an issue then whats the downside?
In all honesty, you're better off just waiting until a suitable NA pops up, then selling it when you're ready for a turbo. Once you start pulling apart an engine, unless you're building up it lets all the gremlins in.
https://www.sau.com.au/forums/topic/231193-removing-turbo/#findComment-4101411
Im still gonna get a quote on the job anyways to see what price they reakon
https://www.sau.com.au/forums/topic/231193-removing-turbo/#findComment-4101508
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
