Do you like golf or not?
10 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi Guys
im a pretty keen golfer and play off a pretty low handicap. Just would like to know who in SAU ACT and NSW plays golf and if they have a handicap what is it?
And if anyone wants to go have a game or hit some balls at a driving range some day?
I play off Scratch and was a pro for a short period and would be happy to throw some pointers at anyone that would like some help in there game.
Adam
https://www.sau.com.au/forums/topic/231283-golf/
Love golf!!
Im down for a game anytime, and would be very fun with someone who knows a thing or two. Me and a mate were at narrabundah driving range on the weekend and i was landing on the 250 sign so pretty happy about that.
https://www.sau.com.au/forums/topic/231283-golf/#findComment-4062220
Yeah cool guys. We should meet up and have a bash some day soon. i need to get out and play and train again as i have a few tournaments comin up.
I'm free every weekday during the day and some weekends.
Give me a call anytime - 0401 133 866
and we can work out something or post it up here.
I am going to be out practicing, nearly every day for the next few months.
https://www.sau.com.au/forums/topic/231283-golf/#findComment-4062241
i used to get bored and hit from my backyard to the front yard (over my house) and then suprisely i sent a ball onto the road out the front which is a pretty main road, nearly hit a car and all that, decided i would be better off not, so yeah
been driving range a few times, but never actually to a game...bet i would suck haha
https://www.sau.com.au/forums/topic/231283-golf/#findComment-4064089
Well it seems golf its not huge in ACT SAU...but anyways if anyone want to have a bash, hit some balls at the range or do pitch and putt, im free untill 4pm all week.
PM me or u can message me on 0401 133 866.
Adam
https://www.sau.com.au/forums/topic/231283-golf/#findComment-4078630
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
