For those of you who couldn't be bothered looking at the link
The new “International” circuit layout - 4.7km in length
The 4.0km “Full” track
The 3.0km “National” track
The 2.2km “Corporate” track
The 1.7km “Club” track
The 486m “Drift Bowl”
The extent of the existing track
I like how a combination of tracks can be used at anyone time - except the international of course.
Though I don't like how the drift bowl will be part of the international track...........
Drifting by nature, tends to ruin the surface, especially when they drag all the dirt onto the track. Else I like.
That is one of the nicest, most balanced and ingenious layouts of any track...
Would've like to have seen a tighter last corner, aside from that though, looks really technical, and the long main and back straights allow for great passing spots! :P
Send THAT BLOKE TO BARBAGALLOS!!!! :P
"John Cotter, the President of the ARDC, announced that the master plan would be a way to cover for the impending closure of Oran Park, as well as provide world-class facilities to hold world class events, such as Japanese Super GT, FIA GT World Championship and GP2 Asia."
Super GT....super!
Would've like to have seen a tighter last corner, aside from that though, looks really technical, and the long main and back straights allow for great passing spots! :)
Actually, to me, it looks overly tight with only one potential overtaking place. Loads of mickey mouse stuff & only one even remotely high speed corner in sight. :P To be a good circuit it needs a couple things - namely elevation change combined with high speed turns.
On the upside it looks to have flexible layouts. Does anyone see the resemblance of the National Track to AIR? They have packed alot of tarmac into a small space - maybe too much?
Hopefully there will be something in it for the paying spectator, not just the bloody corporates.
So please keep this sort of thing away from Wanneroo.
Edited by djr81
yeah I'm a bit of a sceptic too. and it's as shame where we once had a nice, fast, open turn 1 we'll now have a hairpin instead. d'oh.
there are a lot of positives though. :P and it does make good use of the space.
my only other gripe is the drift track should be seperate from the main circuit and they should build another, BIG skid pan and actually let clubs use it for khana events and even drift practice etc.
Looks fun.......but!!!!
I'm with djr81. It also doesn't look like it has the same high speed flowing as the current layout.
No more high speed turn one!......I'll miss her :google:
Drift track defiantly needs to be bigger and separate to the main circuit.
Personally i don't like it and I definatley don't like the implications of making it happen. The current track is great as it is,,,there's plenty of overtaking spots unlike most other tracks in skippy land.
My only bug-bear with the current setup is you can't see shit as a spectator.
Why not bulldoze coporate hill and turn 2's hill flat,,,build some simple covered grandstands and heaps of stepped seating like next door.
Neil.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
