ive recently just brought a GTR yay!
Its got a cat back exhaust so im thinking first mods to get front pipes and maybe dump pipes.
at just as guess how much kws will i pick up after the dumps and fronts?
everything is stock atm apart from a mins ECU.
cheers
https://www.sau.com.au/forums/topic/231797-front-pipe-and-dumps/
yeh right... never thougth about that.
im getting a bosch 040 pump to put in there this week, reason being i had to change over the fuel filter the other day and it was the factory stock filter! i weighed about 1 kilo, full of crap, so i figured its about time to change the pump as well. should i get an AFR plot before changing the pump?
Front and dumps+mo boost then dyno...then wait for the ceramics to let go after a few days, week, months whatever and then your in the club :)
Seriously I'd get the tune sorted then leave it alone...if you want to keep money in you pocket that is. Pump's a good idea though.
you'll probably find that Mine's ECU of yours is tuned to Jap petrol (102 octane most likely) and it'll be running lean. A fuel pressure regulator is probably needed, and if you're upgrading the fuel pump make sure the relay is in good order, making a full 12V at the pump. As for the turbos, its just a matter of time. I've heard of people running 14psi consistently on the ceramics with no troubles at all. Me on the other hand, as soon as I took it to the track they clapped out after the 5th lap. $10k later and its back on the road :worship:
As for the dumps, fit them when your turbos eventually blow, it wouldn't be worth the cost of labour otherwise.
When one of my ceramics let go, 13psi, I went for 2860R-5's. There are a few knowledgeable guys here who believe that destroying a ceramic is a death sentence. My engine tested fine and continues to have good oil pressure after 17K on the new turbs. Cat...what is that lol
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
