hey guys, i m driving a 2004 nissan 350GT, just wondering can anyone get the projector headlight, which is the same as 2006+ model?
and i would like to get a HID on the car, anyone in brisbane can recommend me some shops?
thanks guys...
i m having fun 2 drive the car...haha..
https://www.sau.com.au/forums/topic/231877-looking-for-help/
I was looking at the 2006+ HIDs on ebay.com (USA) just today... The ones from the Infiniti G35 are the same (as they are the same car as the 350GT).
They look pretty damn sexy, and don't cost that much in the scheme of things.
does it fit the car?the one u were looking at is come wiz HID?
Yep exactly. As Chris said the US versions are designed for the US roads who drive on the opposite side to us here in Aus, and Japan. So the lean will be on your right side headlight, going into oncoming traffic.
How bad is it? not sure, i know there is one member here who has done the conversion.
I may be able to get my hands on the ballast and ignitors if you want the current headlights to be xenon, but it won't give you projectors.
Cheers
Bobby
The question was about fit and they would :(
Nah you are right. You can also find them on yahoo.jp auctions, use Import Monster or something. Probably looking at $6-700ish/set deliverered if you are lucky. I was trying to keep it simple
Edited by MaXiMuS007
Thanks for the reply guys...
do u guys know if i wanna get a HID CONVERSION KITS on the current headlights, what size of bulks do i need?H1 OR anything else?
and Bobby, r u selling any kind of the HID KITS?
one more question, where can i install the Kits on the car in Brisbane?nice and cheap shops?
thanks again...
Hi Penny,
No I don't sell HID kits but a mate is a bit of a HID guru and does alot of conversions in the motorbike world.
He can get any part of the stock HID kit you need, from Ballasts (which should hopefully still be there as Chris said) to ignitors which are usually cut during compliance.
As an example in my case the Ballast was still there as it forms the cover for the high beam (at the back of the headlight) and I just needed new ignitors. He got these for me for around $100, joined two wires added globes and i was back to Xenon. 30mins work.
If you know what you need let me know and I'll see if he has them. He loves the stock units on the V35's and uses them in a lot of conversions as apparantly they are a nice reliable unit.
Cheers
Bobby
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
