CRD Dyno day - DATE CHANGED - Now Oct 12th 2003
Guys there will be no "running order" as such, however it WILL be first in best dressed. Cars will be lined up in groups of 5 or so.
Those who are on the waiting list as shown in the first post need to come along on the day and see if a spot opens up.
  • Replies 240
Hello all,
Never been to a dyno day (or CRD for that matter), so I'm hoping someone can help me out with a few questions:
1. CRD Dyno - Will this dyno cause problems with cars that have low-ish front bars? My car has one such offending item and I'm not sure if it will get onto the dyno - that said, my car has been on a dyno before, so if they are all standard in this regard, it should be ok i guess. If somebody tells moe otherwise, I will take it off before I go.
2. How long will the day last for - the start time is 8-9am, and there are 35 cars running. Do we only get one run each, and if so, then what time approx would we get through all 35 cars?
And a final one to satisfy my curiosity - any press attending? (ie should I wash my car :D)
Thanks for your time, and see you all there!
Chris
Chris
1: Shouldnt be a problem
2: the runs are power runs with the option for people to ask a few questions assuming we get through the cars at a reasonable pace. 35 Cars are running, perhaps a few more if things go well. The day as mentioned is first come first served. Cars will be lined up in order of arrival so get there early to ensure you arent at the back of the queue.
3: im sure plenty of people will be taking photos and the like so yes wash your car
course they will provide teh graphs dude..
On another note?
I had 2 spots? and only 1 seems to be listed????
I used to have a second spot up there?
I have a special GTiR coming along in the second spot.... :D
If I cant have my spot back - please add it to the reserves as he is defo coming.
Oh and I wouldnt think Mongie is coming now???
he wrote off his R33 GTR???
Thanks
Michael
Originally posted by CS_180
joking as if i would be able to get a tv away from a criminal........
yeah i may as well try get  a bone off a pitbull
oops!!! wouldn't want you doing that!! thought you were getting it off a work friend or something :D
:bahaha: at franks....your cars not stock!!! :D
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
