Hi All,
I'm just wondering what problems there may/would be installing an R32 turbo on an R33. I know lots of people put R33 turbo's on R32's and have read something about a restrictor in the oil feed line of R32's so that there is a different oil pressure due to different bearings being used between the turbo's. Can anyone confirm this? Just wondering if anything special needs to be done swapping them the other way around.
Ur prob thinking why would I wanna put an R32 turbo on an R33? Well the turbo on my R33 blew and the only 2nd hand turbo I can find for it is expensive, so for that price I would rather just buy an aftermarket one. Only problem is the person that looked at my car also believes that the engine is damaged, so I don't want to buy an aftermarket one for which I will need to get car tuned on dyno if I'm not certain the engine is ok. But, I want to put a turbo back on the car to confirm whether or not there is a problem with the engine once the turbo issue is resolved.
So, I was thinking maybe an r32 turbo might be a cheap temporary option for me to check how the engine goes with the turbo issue resolved. From what I've read it seems an R32 and R33 turbo is a direct bolt-on swap, is this the case?
Cheers
https://www.sau.com.au/forums/topic/232122-r32-turbo-on-r33/
R33 turbos aren't expensive, certainly not anywhere near the realm of an aftermarket turbo. And even after you find a problem (if there is one) with the engine, you are still going to have to remove the R32 turbo and replace it with something larger.
If anything, the R32 turbo could damage your engine as being undersized it will be running alot less efficiently which equals higher inlet temperatures. Also, since the turbo will be running higher speeds to keep up with the 25 you risk having the turbine on the RB20 turbo failing.
RB25 turbo with manifold, dump and lines went for $150 on SD.com forums today. Saw one going on this forum last week for $200. Found one (again this forum) rebuilt for $500.
If you are getting aftermarket turbos for this price then they must be cheap copies
Edited by daisu
Rb25 turbos come up for sale almost weekly - and priced @ $400
Not expensive at all when aftermarkets are $1700+
not sure what price you'v been given for an RB25 turbo, but $400 is the limit.
The RB20 turbo is too small, and could cause issues with the tune/ECU and so on being it'll be on boost earlier than normal
I actually live in NZ. The only R33 turbo I've been able to find so far is $700 from a 2nd hand parts place which is ridiculous, but there's lots of R32 ones around.
Guess I will just leave it until I can find a cheaper one since I still have my R32 to drive around in. Hopefully I can find one soon.
Cheers for comments
sorta on topic but does anyone know if rb20/25 exh manifolds are different at all?
reason i ask is the to4e turbo i have is supposed to bolt up to my stock mani & if the rb25 is different in any way it might be good to know.
thanks
Cheers for comments
So just purchase one off the forums here? Living in NZ shouldnt pose one problem.
Have the seller ship it over.
Wouldnt be more than $50 postage at the worst.
Thats what, $250 cheaper to begin with.
Answering the question, yes you can and yes it will work, it will spool early and run out of puff quickly. If you put the stock r33 actuator on it (so its only running 5-7psi) it should cope ok, They don't like pushing more than ~ 150rwkw worth of air, so run the lowest boost you can, and it will get you by (i wouldn't go bouncing off the limiter though)
That said, your better option would be to get another rb25 turbo, a vg30 turbo or similar T3 (an old vl turbo even), you can get them in aus for around $300
Rather than start a new thread................ might as well hijack :dry:
Just wondering if the r33s1 and the r34gt dump pipes are the same??
I know that the r33s1 and r33s2 turbo's have slight differences but that has nothing to do with the dump.
Hopeing 34's will be the same????
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
