Matty,
Congrat's dude! Naaa forget the GTS-4 idea, go get yourself a Racelogic Traction Control system. www.racelogic.co.uk
Here's the system at work on an M Roadster - http://www.racelogic.co.uk/z3mlaunch.avi
I've already asked in "My rebuild" thread but in I'll ask again here.... I take it the internals aren't stock to enable you to rev it to 8k on a regular basis?
Nice work! You're using the RB25 right? I get confused about the T04R too. But I am pretty sure you are talking about the big HKS one right? I don't believe it is BB, or is it? How does the T04R compare to the T51 series turbo? I've always liked that turbo, I reckon it's a great turbo for the RB26 or RB25. Which is bigger?
