Originally posted by MattR
did have. dropped a valve:( on sunday wasent too lean or anything like that, no detination just dropped one
I was thinking it was only a matter of time mate. Reving to 8k on a stock used RB25, something had to give sooner or later :) Ahh well nothin' wrong with spendin' a few $ for a freshen up hey :)
So what's the plan from here on in?
Should have stuck with the old RB20 mate!!!!
At least you know where the limit is now for a RB25 with stock internals - now you'll just have to put a RB26 in it instead
Or rebuild the RB25 - whats the plan?
Chris
Originally posted by whatsisname
I was thinking it was only a matter of time mate. Reving to 8k on a stock used RB25, something had to give sooner or later :D  Ahh well nothin' wrong with spendin' a few $ for a freshen up hey ;)
You win some, you loose some.
Merli states he has been running his redline at 8k for over 11months, with 280rwkw at 1.2bar and stock internals.
MattR, as long as you had fun dropping it:D
Nah not really, didnt even get a real chance to run the new turbo on boost. Happened on the freeway 3300rpm in 5th. Just one of these things you can never predict, at least I know it wasent in the tuning, all the plugs were a little too rich if anything
I was looking up on dropping a valve and apparently there is tell tale signs before it drops as it becomes extremly burnt and doesn't close properly hence causing a slight miss.
Before the valve breaks away from the valve stem it apparently stretches.
Wont know for sure till the engine gets pulled apart. Will fit new pistons and valves and what ever needs to be done and sell the engine. If anyone is looking for a re-built br25det let me know. Cheers Matt
11 months doesn't really mean that much. He might only do 10k a yr & a large % of it may well be mild commuting? How many hard kays has he done on it taking it to 8k? From what I gather Andrew (Merli) is pretty tame on the road, so it'd only be the track days that would be pushing it. Like I said, only a matter of time!
Joel, my car is going good, a electronic boost controller has given it a fair whack more of midrange, but haven't had retune as I am deciding on whats next - probably programmable managment
MattR - good to hear that it will be back on the road soon!!,
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
