i'm planning on running 20psi of boost on a rb25det. will the coil take this and what heat range plugs do i need all mods are listed below
Built motor pistons bored to 40 thow. rods nismo oil pump hks head gasket, Race bearings. Main studs and head studs. stock valve train springs,cams etc. stock head.
HKS Gt 3037pro s turbo kit. from japan
HKS twin plate clutch
Power fc with hand controller
World Electornics Boost controller tbc-1 (best money can buy)
Full exhaust NO CAT ( 5 zigen)
Front mount intercooler
Z32 afm (30p00)
100mm intake manifold and T body.
Sard 800cc injectors and rail
Sard in tank 280 lph fuel pump
HKS M45 spark plugs
BF goodrich R1 tyres (Drag)
After market air filter
Ksport coil overs
you need to change your coils for that setup if ur planning to run 20psi.
stock coils uaually crap themselves at 240-250rwk, but some have seen higher figures. Youv'e spent all that money, spend a few hundred more on splitfires and do it right :(
Edited by R33GOD
Mate can you hold off for a couple of days until search works?
All these questions your asking have been covered time and time again... and it'll also stop ill informed responses like the above :(
Because i can tell you now stock coils can do over 370rwkw if in good order, because thats how much power i made on em.
And plenty of people have made more. LOTS more. :(
