Platinum Car Audio and Interior having a massive midnight sale..
All stock must go, for all your audio and Interior need.
Its on Friday the 5th of september 2008
From 7 pm to midnight
17/287 Victoria road
Rydalmere
Same complex as Touge Tune
Alot of car spaces avalaible
So if you looking to buy cheap audio gear or chill around come down to the shop..
few of the Brands they have in stock:
HiFonics , Alpine, Kenwood, Panasonic, Nakamichi, Mb Quart, Soundstream and more
Mikyel is online now Report Post Edit/Delete Message
Need a sub and a box, ill go have a look
haha now I have that SNL 'my cock in a box' song stuck in my head :D
I might come down, need some new speakers mine are starting to sound shitty.. I think these are the same guys who installed my alarm........
This sale was great yesterday!
Went at about 9.30 and they still had customers coming in and out, picked up this dual amp kit for 129 =D
http://www.ryda.com.au/Aerpro-AP963-1200W-...8ga-p/ap963.htm
Nice !!
Checked out the DVD units aswell. Some were for just 650!..
But ive decided to buy the Pioneer AVH 5950
And another plus was that i saw two skylines haha! i didnt take my car down, shouldve lols.
Black 34 and a white R34 pleazn (in numbers and letters, forget how he spelt it)
MRXTCZ
Nice nice, i was looking at the Clarion DVD head units.
Looked tempting but they dont play Divx and i think they only have 2 RCA or was it 3.
Lemme' know if you got any Pioneer AVH 5950's on sale !!
MRXTCZ
sorry, we dont stock pioneer or sony.. it got too many problems with it, specially head units..
they have clarion,alpine,nakamichi,kenwood,soundstream,hifonics..
the new top of the range 12 inch hifonics will kill 2 type r alpine with 1600rms..
anyway i will ask them to sponsor this site if lots of ppl here interested in audio gear..
When you said there were problems with Pioneer headunits what did you mean ?
PM me if needed
Anyways, i came down the other night and was tempted to get the Clarion DVD Headunit, it was Single DIN, 7" touch fold out, 650 i think it was. I didnt get it because i forgot to ask if it had 3 RCA's and if it had Divx Playback/
You got anything else in these specs ?
Single DIN
7" Fold Out
Touchscreen
3 RCA Preouts ( for 2 amps )
Divx Playback
Additional RCA to plug in additional screens
And remote control ( not too fussed )
Lemme' know man.
MRXTCZ
ok then... Clarion... the rest of the speakers i have are that brand
clarion 12 inch subs start from $80 depends on what models and specs you want
PM me if needed
Single DIN
7" Fold Out
Touchscreen
Divx Playback
Lemme' know man.
MRXTCZ
kenwood will be $1000 and clarion $1200
i have to get back to you on model number..
with pioneer most prob is the laser..and sometimes you get engine noise..
change deck and its gone.. so not cable problem
hm....How much for a Alpine CDA-9884??
Been looking at getting it from the States, but maybe u can do a better price :/
Let me know
Chris
Hi.. sorry they dont have the 9884
they have 9886 for $399 and 9882 for $289
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
