Ok gurus, need assistance!!! and thank you in advance :D
So i just bought a standard cheap second hand turbo timer and i have a basic alarm w/ immobiliser installed in my car...
so the question is can i still install this turbo timer without screwing up the alarm and will both still work as the should... cause im guessing the engine gets immobilised as soon as u activate the alarm...? Ergo how do you keep the turbo timer running engine and delay the immobilisation lol... if that makes sense... without upgrading the alarm system :D someone said something about a relay before but i have no knowledge in that area.
cheers again
Alex
https://www.sau.com.au/forums/topic/232612-turbo-timer-question/
Hey guys, its a mongoose m20s :) basic alarm and imobiliser
as far as i noe all the mongoose ones wont have a problem with a turbo timer as i have one with it. But the way I check is to simulate a turbo timer running, for example sit in ur car have it running the press the button on ur control to lock the doors and now switch off the car and wait to see if the immobliser engages if it does and doors are still locked then turbo timer wont cause a problem
I have a question:- Isn't a turbo timer an invitaion to thieves? I.e. (hot) Ignition wires easily available (no key needed) to anybody interested in having a fiddle, or maybe more???? btw It is a fair-dinkum question.
Hey guys, its a mongoose m20s :O basic alarm and imobiliser
no go. if it was a 60 or 80 series it would not be a problem. sit with the car for 30 sec or so. it will save the car from becoming spare parts.
not so. viper alarms will arm with the key on. (antihijack function) mongoose wont arm at all, autowatch will if the timer option is enabled and the timer relay installed.
VERY true. last car I had here I proved a point on. I had a bit of 10 awg wire so I shorted the wiring on the timer and clutch started the car, drove off with the customer watching in disgust.. the car had a basic remote start alarm on it.
yeah but u should consider that on average a turbo timer will stay on for 30sec and buy the time u get out close the door lock it and walk away far enough the car turbo timer would have shut off and the alarms immobiliser would have engaged.
so unless running it for long periods of times should be safe
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
